Using E-gate MegaThread
hwsstx
Today accompanied a lady friend to re-register for MACSv02 - previously unsuccessful due to forefinger prints issues.
Today similar issues but she asked whether can try another finger & the nice Officer acquiesced; & so she tried her thumbs.
She managed to register with her thumbs!! 👍
matrix05
Today accompanied a lady friend to re-register for MACSv02 - first time unsuccessful due to forefinger prints issues.
So to register Macs2, just look for the dedicated Macs counters. Just passport, no other document needed? Need to show proof that you applied MDAC ?
kmlee316
Thanks to all the great tips on using the e-gate, it has helped tremendously!
A few days back, I took First coach to KL and registered accordingly. At the 2nd link, the bus dropped me at a building parallel to the ones the CWx buses were using.
These *did not* have any e-gates but the officer kindly directed me to another building across a road where the e-gates were. Remember, use the ones on the extreme right!
Then on the way back, I noted the same and went over - and the building was locked! All the counters *down* - wah lau eh.
So kwai kwai cross back the road, go back to manual counter and explained that I had no incoming chop on my passport because I used e-gate on entry. The officer put an exit chop and *signed* on it saying I had entered via e-gate and hence no entry chop. Officer also said the building was temporarily closed.
Dunno what will happen next trip😰
Habrosus
Which day and what time was it that the front building was closed. This building's normally the one open 24/7.
kmlee316
Monday 25/3 about 1650 hours. I also saw a whole bunch of Causeway Link buses all parked. But no time for small talk with the officer as my coach was waiting.
kmlee316
I think the key takeaway is what to do if somehow you cannot exit MY due to problems with the e-gate.
Join the manual queue, explain you came through e-gate, get a chop and make sure the officer signs off on the chop - that you used e-gate for entry.
Habrosus
Cleared Tuas eGate yesterday and returned today, smooth sailing
hwsstx
hwsstx
Today...at North Side
7.47am - Bus dropped off at SG's CIQ
7.50am - Cleared SG's CIQ
8.02am - Cleared JB's E-Gate
Sitrep
• Manual Counters: < 20
• E-Gate: 👍👏
• MACSv02 applicants: < 20
• 3.48 @ Sentral
Less than 20 applicants for MACSv02
timmy75
For registration, remember to get ready to show your MDAC registration email on your phone/hardcopy at the dedicated registration single queue with 2 counters. It is on the right side of the Malaysian-only e-gates. Scan your index fingers, no photo taking and can use immediately at the egates on the right side of the registration counter. The JB custom egate registration is only Mon-Thu between 8am to 7pm.
hwsstx
7.52am - Cleared SG's CIQ
8.07am - Cleared JB's E-Gate
Sitrep
• Manual Counters: < 10
• E-Gate: 👍👏
• MACSv02 applicants: <10
• 3.48 @ Sentral
ralliart12
SG using MY's E-Gate must submit MDAC.
I’m confused, due to this CNA site: if I’m not doing eGate registration, as a SG citizen I actually do not need to prepare MDAC? But if I’m doing eGate registration I need to?!
then after I successfully register for eGate, do I still need to prepare MDAC before I use the eGate each time?
ralliart12
Actually which are the eGates that SG citizen supposed to use? The ones on the extreme right where all the Malaysians use, or the few right next to the eGate registration manned counters?
hwsstx
Must submit MDAC for both, registration for E-Gate & using E-Gate.
No restrictions, all E-Gates can use.
