Vios owner group
EJB
Engine bay strut bar without lowering is like no effect actually, cuz I'm currently on this setup :s13:
Slight... very SLIGHT improvement in cornering and anti-body roll, but not the best without lowering. :) I was on engine bay strut then lowered.
keithchan
Consider a set of good tires in JB! RE003 is good, each is only about $70+ for 15" there.
Just replaced all 4 tyres to Michelin XM2.
14" at 210RM per piece.
Major, major difference from the Super crappy falken tyres.
BuGGi3
Ah yes, avoid falken. Might try XM2 tyres next but no reason for me not to use RE003 since the price is thereabout the same.
EJB
Yes there is. When you upsai the rims to 20".
laxer
:s13: don't think that i'm the only one. i'm sure there are many others running BEYOND that speed hitting 100% with Vios.
Only if you're confident with your setup and vehicle condition. 1st thing to change out will be that 5.5jj stock rims.
Mine is a stock ncp42
Change rim to 17inch (Heavier and stable during high speed)
Added front strut bar (Ultra Racing)
did 170km/hr @ nshw, don't dare to go higher cos its stock engine.
UltraWoman
how to know what type of engine oil to buy and bring in JB ? and Quantity to buy ?
maybe a website for me to have a good read or brothers here can advise thanks
like my earlier post stated, just took over the car from my father. a real noob here.
my dad car is toyota vios 二代
liquidh
The owner’s manual will state the type of oil.
But typically most 5w-30 or 5w-40 will suit your Vios. Get from a known brand to be safe.
BuGGi3
Nice setup. 17 inch rims might be heavier and tyres are expensive. I'm on 15 inch 6.5jj, definitely much more stable than stock 15 inch 5.5jj.
BuGGi3
5W30 or 5W40 fully synthetic. For normal oil changes, do in SG is good enough. Check out Acma or workshops near you.
keithchan
Is ECU resetting required if say I took over the vehicle after it has done >170,000 km?
Theoretically ECU should constantly collect new data and adapt accordingly but may take some time?
BuGGi3
Maybe you can help us understand why do you want to reset ECU or what is it that you want to achieve? For my case, I didn't reset when I took over the vehicle at 130k km.
EJB
Talk to MXTradings, I get all my oil from them.
EJB
As Buggi3 korkor said, first understand why you want to do that first, then weigh the pros and cons, resetting is very easy, unplug the power cable to the battery for 30-1hour, all settings including your radio will be gone.
However, I seriously doubt it will do much...
fake_oranges
I think too much respect have been given to the Vios ECU
Last time forum got some urban legends:
-ECU very smart to adapt to driver. You want fast have to drive fast and the ECU will make your car faster
-Every batch got one R&D car. Will be especially powerful
-Cut holes in airbox to increase airflow
-Vios too powerful for Goodyear Eagle F1
