VIVIFI
yusoffb01
The vivifi 9 dollar plan is permanent right? No gimmicks like after 3 months revert back to 20?
get zero1 $6.90 better
xsoldix
Anyone got bad experiences with vivifi?
can share code with me? (Received. Thanks. )
sms receiving (otp) while roaming any issue?
thanks!
xsoldix
Usually how long it takes after apply to able to collect sim?
hoping to collect it while on leave these 2 weeks. :)
y0natan
So I have decided to terminate my Vivifi number because, well, I don't need the data anymore. Under their T&C at their website, there's a sentence saying that if the number that I have with Vivifi was issued by them (in my case, yes), they will recover that number for SGD 50. Can someone explain in simple language what that means??
Thanks!
After you terminate a number, if you want to activate again with the same number, they will charge you that $50. It can only be done if it's their number. If it's number ported-in from another telco, the number will return to the original telco.
Arandalo
Is this the industry standard for all MNOs and MVNOs in Singapore whereby all mobile numbers will return to the respective operators for both postpaid and prepaid?
Spongy
Any difference between gomo and vivifi network coverage or speed?
I tried GOMO 5G for two weeks and gave up as the data and voice connection is buggy on my son and my iPhone 13 Pro. I even reset my phone network settings and it still sucks. I’m on Vivifi 5G now and the connections are very stable. I keep hitting the call limits and cannot make calls anymore so had to top up to continue making voice calls as VOLTE is not supported.
amazingone
What has hitting the call limit related to volte?
xiaohaengbok
Can I have a code please? (Got many codes already. Thank you all!)
Thinking of signing up for the 20GB plan
