ecan07
- Jun 26, 2008
and what tailor is this?My personal tailor charge me 150 for pant and shirt. So far so good.
People commented very nice and presentable
Keen to know how was it. Do you have them already? Can share review?My initial budget was like 120 a shirt. I just went with Ethan Men given their very reasonable pricing. Hopefully it comes out good.
Have you tried HST tailors before? What I understand is that shirts are typically MTM but my very old experience with them is that HST accounts for more unusual measurements.Hi all, I am in need of some new shirts and want to check with the more experience of you here in terms of cutting -
I have had some very poor experiences with tailors here to the point I am dreading going through it again. No matter where I go there is always excess material on my upper back between my shoulder blades. Their solution is always extremely high darts which is not professional and does not solve the underlying construction issue.
To those who understand construction – how should this be resolved?
Is it the shoulders that need to be taken in more? or is it the angle of the arm sleeve?
Do any tailors do cuttings by hand here? I am tired of the front facing sales people that don’t know about construction.
Thanks for the help
Thanks for the help
I tailor my shirts with collaro (just ordered 2!). Always satisfiedAnyone can recommend tailor that does business shirt between 150-250? Tried CYC, Rossi which is around that range but would like to explore others. KayJen is not bad but it cost >$300 for a basic white shirt![]()
Will check them out, thank you.I tailor my shirts with collaro (just ordered 2!). Always satisfied
If first fitting is too small, it's a problem as fabrics cut already very hard to let out. If can let out, it means the end product will not have much excess fabric at the seams.
Normally first fitting is a bit loose then the tailor 'shrink' the loose parts to fit. Macham like vacuum wrap
I also ordered from Collaro before. Measured my own shirt and +/- some of the measurements. So far so good... And don't need to step out of my house.Did they measure you or you measured yourself and ordered online?
I did one shirt with them back when they were still at Chinatown and it came out too small. Gave feedback to them during first fitting and one of their guys (not Travis) said the fit was just nice. Being new to tailoring back then, I just accepted it as is but my subsequent experience has proven that their fit was indeed too small.
On another note, does anyone have recommendations for affordable short sleeve knit tees that go well with casual trousers?
Nice. Their Lucca button down is my favourite too.
At that price point... Might be better off going to brick and mortar tailors. Wider range of fabrics selection...Yes, saw a review from Feb 2022 someone made on YouTube. The same shirt costs $60 more now
