Where to tailor clothes, continued...
aabeesee
any place to recommend for alteration of suit? i went back to the original place where i tailored from and they're charging $60 per area. :/
Vin1234
Hi! I’ll be entering the workforce soon and I’m looking for trousers (slim fit/skinny fit) with elastane, any tailor to recommend, budget <150 :)
wacks_505
Sure. I might pop by a more budget option like Lai En or Este Bartin to commission a simple pair of chinos. I'll update the thread if I do so. :)
yeswecan
Wanted to get the ball rolling by sharing a recent commission I had with a relatively new tailor. Wanted a sports jacket that I could wear when I want to be slightly more dressed up. Decided on this Reda wool-linen fabric.
Any comments welcome!
Wa love the cutting!
May I know the cost of this?
Thanks!
strezzor
Is Lai En still the go-to choice for value for money shirts? I recall reading reviews about workmanship deteriorating. There was another shop recommended for shirts - also in industrial area but can’t recall the name.
All in a Day
Yong seng?
martinnhj
Probably too late to share..
Those who want alteration in Orchard can find a newly local shop in Lucky Plaza basement. Opened last year. Just behind 7-11. Reasonable pricing and fast. Very friendly aunties. =) Also have bespoke pants, shirts and suits.
aabeesee
hey not too late at all. do you recall what it's called?
elvintay07
Suspended
Guys, I understand we can tailor pants without belt loops (using some draw strings to tighten). I wonder whether that method is reliable? Heard sometimes the metal buckles will break. Then will the pants become very loose?
DriftKing
Any recommendations for tailored to even off the shelf non iron or easy iron shirts? I've been running exclusive Uniqlo ones.. getting bored
Clinomania
Side adjusters are mainly for aesthetics as there is only so much you can tighten the waistband. Plus, tailored pants should be fitted to your waist anyway. You can also seek a replacement for the buckles, usually at no cost.
