Whitestone Dome Screen Protector Problems..
renfred89
Is it same like mine?
this one confirm is not enough glue at the top portion. LOCA shrinks 0.5% when fully cured, when u get the bubble lor.
jess_sy
Just a quick update on my wsd. Seems like FP is getting a little bit better. I only need to aim at the middle of the FP logo and press harder then it will register and unlock phone. Works like 8/10. Although i prefer the sp-less version whereby I can press lightly and still read.
Same here. Need to apply abit of pressure. Re-registering a few times works too.
Ahkunkun
I am one of the unlucky 30% that totally doesn't work. The lady cured 20 mins for me and it didn't work at all...
athenodorus
U really think it’s 30% affected only? I think a lot more are having issues just that they don’t surf this forum. But anyway those that wanna continue risking and don’t mind wasting $ can go ahead and try luck.
Gloom me
Ya lor... When I was installing mine, there was this malay lady there also before me. She had her hands full of shopping bags.
After she installed hers, never even check. Thanks and bye.
I wonder how's hers? :s13:
Reborns
anybody can list the cases that will work with the whitedome SP
incase after they solve the FP issue with some batches
then I will go and get it installed
but need to know what case that can buy
blue_quartz
The SP covers the screen just enough, so it should work with most cases. For starters, the default one with in our S10/S10+ box works fine with the SP.
Day 2, my FP sensor is still very 'weak'... hardly any better. Maybe try to cure a few minutes under the UV light later...
teArsBoy
So much uncertainty about the WSD. Guess now the best solution is just put a normal film protector and wait out?
ra[g]e
I think best solution is to leave the screen protector that has already been pre-installed on, until we know more about how the WSD will turn out...
Deavenger
Although I can get around the fingerprint issue..I changed my wsd twice due to the top part of it being able to stick properly.. but since second one still cannot stick.. I changed to some other product cause jo point keep trying..
Now without any sp..the fp scanner is indeed very very fast..almost instant and so sensitive
shadow84
