Anybody know the price of mont-bell in Japan if it's cheaper than Singapore
for the same montbell down jacket, the prices there are two thirds of what is sold in SG local agent.
Whenever I go there,I'll sure whack their merchandise. It's not overly expensive since it is an Osaka company that makes outdoor equipment and apparels for the locals. Shinjuku station south exit has a branch which have English speaking staff. Alternatively, another branch at Okachimachi station near Ueno. Whichever is more convenient.Thanks for that . I will go there to purchase . Got to find the shop first
4-10 in tokyo manageable...
get a pair of boots, uniqlo ultra light down, a heat tech long sleeve inside and maybe a heat tech vest. plus tight fit jeans. and add a scarve and beannie, you're good to go. make sure your clothes are snug fitting to ensure maximum insulation.
Sent from LGE LG-H959 using GAGT
Here you go.
http://en.montbell.jp/shop/japan/
if it's tummy, wind will travel upahah usually i dont zip up
i got natural wind resistance
my stomach
if the TS worry just get a down with some wind resistance or proof layer
it will keep u warm and aslo scarf if the person neck is weakest link
for me i used to use my good old northface
but now i use my uniqlo 4 way even in sapporo in winter
Is Montbell better than Uniqlo. I have seen the uniqlo ULD, really hin and light. Is Montbell's the same? And are ULDs considered windproof?
for fully waterproof down jackets, look for companies that does ski and snowboarding clothing, or you can look for professional outdoor gear companies.
most down jackets are not waterproof. waterproof down jackets are mostly very bulky and impossible to pack small.
but all down jackets are windproof. the fabric used must have a very tight weave that prevents down from escaping the clothing. the only issue is that because of the stitching pattern for the baffles, those stitches may allow small amount of wind to pass through. the small amount translate to heat loss from the jacket.
montbell has many nice down jackets. but you are looking at paying twice the price of uniqlo's.
and btw, uniqlo having their sale now. their ULD is back at 4990 yen. you can buy 3 uniqlo jacket for the price of the cheapest montbell. anyway i have jackets from both these companies, so they both have their uses.
and if you really want waterproof, then you are better off with a synthetic insulation like primaloft. many fashion companies have down jackets in this synthetic material - zara, gap, etc. synthetic insulation retains heat better even when damp. and they are usually cheaper. the downsides are that they do not pack small, and they are not as durable.
4990 yen for Uniqolo is in Japan? Anybody know till when it ends?
Tia
