davidwong
I will advise getting from local seller becos their QC not the best and if kena spoiled very difficult and expensive to send back where as the local seller I bought gave 6 months warranty
can get t1xs shipped from taobao at just over 60sgd.
guile
any recommendations?????????????????????????
Reception varies between earbuds and the devices you're pairing it with, plus the environment as well.
Maybe you can give example of the type of environment you're losing reception in? Where your device is kept when you're listening to the earbuds? These things usually have good reception at line of sight.
Toader
Sony WF-SP800N. Water resistance (I wash with soap and water ) good battery life with noise cancellation. Good bass for those who like bass. Sound quality can tune to near WF-1000XM3 quality with the manual equalizers. Great battery life but no NFC and wireless charging. USB type C connector.
runforyourlife
Moderator
Moderator
Guys what’s a good price to get WF-1000XM3?
Do you guys think it can be used for sports? Like gym, cycling, running..
out of budget. looking at chi-fi.. thank you
the truedot is damn bad. It's connected to my Pixel and a bit of jerking also intermittent reception
Toader
Highly recommend you to call Sony for testing kit and test fit personally. Its not suitable for everybody. But must try out all the sizes and make sure your ears are clean. I've used them for gym and jogging no problem though. But its not water resistance so do take note.
Thats why I bought the SP800N.
guile
There's 20% coupon min spend $50 at Shoppee valid till end of today
Sent from Samsung SM-N975F using GAGT
Crayon Shinchan
Currently using wf-1000xm3.
With current choice looking for a budget sports earbud. Is t1xs or creative Outlier a good choice? Or any even cheaper budget for me to consider?
Sent from Imperial Chancellor (丞相) of Shu Han using GAGT
