ThinkMe
Usually what's the cause of drop in connections? Not wore properly?
Recently my T1XS will drop connections while walking or when the bus ebrake...
storm913
I honestly think it is because of the increase in use of trace together app, causing BT connections to drop more frequently nowadays.
ots
Got my fiil t1 pro during the 11/11 sale. To use at the gym. The bass quite shiok. iOS app can’t detect t1 pro. Have to use android. Connection very good, compared to sony wf-1000xm3. But the touch buttons a bit sensitive. Towel accidentally touch also will react.
lenseview
Hii,
any recommended bluetooth earbuds to play flac music?
thanks.
If you are talking about hearing the higher frequency of your flac, dont think so. Bluetooth transmission frequency band is 20 -20000. Most earbuds are also 20 - 20000.
If talking about 16 bits or 24 bits, aptx hd might be able to support.
Not sure about sony's headphone with ldac tho. They might be able to get the higher frequency.
Anyone with better understanding on this topic, kindly share any info. Kind of interested to know more as well.
DigDub
The phone will re-encode the flac to the codec that that is supported by both the phone and the earbuds so that the earbuds can decode. So even if a high bitrate codec is used, it will still not be the original flac quality. Unless it is a loseless codec which I think no bluetooth standard supports at the moment.
Vulpix
Moderator
Moderator
So fast get already? You use shopee? Still waiting for mine... :(
pcteo9984
I have a pair of earbuds which i use on my daily commute. However it seems that i always have dropped connections during the evening peak hours where my slave side will stutters...is it normal?
ksksksks
I placed my order Ytd afternoon on Shopee from local seller 88.99 after $1 voucher. Now already at j&t warehouse, should be out for delivery later. Will update :s12:
tohchr
Anybody got any ear buds to recommend for calls?
Budget? If deep pockets, Huawei Freebuds Pro. The call quality is one of the best which I had used. Very loud and clear, opposite caller can’t even hear the loud fan directly behind my back. I’m connecting it with an iPhone and also Huawei P40 Pro at the same time. One is personal phone and the other one is company phone. Whichever phone had calls coming in, I can answer it without any issue. This is so far the most reliable dual blietooth connections I had used.
Henabi
Actually if need do calls for long durations and on a regular basis, Which is what I need to do now cuz WFH... also need to consider the possibility of ear fatigue.
When WFH first started, I started with wireless earbuds
At first it was ok.
but then ear fatigue started to set in... The number of calls per day started to increase.
There were days whereby I simply don't have sufficient time in between zoom calls to recharge my earbuds
and I decided to go with wired earpiece or headphones
Sent from Henabi virus using GAGT
davidwong
Haha just show you not deep deep pockets, if not can get 2 pairs of huawei free buds pro 2 haha 😂
At first it was ok.
tohchr
At first it was ok.
Yes, headphones with bigger ear cups are better for long hours wearing, that’s for sure. I’m also working from home and I only use tws when I’m required to go back office on certain days. Else when working from home, headphone is the way to go.
