storm913
What does that mean tho and which phone
:s13:
On note 9, once connected, my spotify shows up weird. First time seeing this after trying countless tws. But wow the sound sywhe is great on t1 pro. Probably my favourite now. Second will be SE 3.
ksksksks
No idea tho.
Yes China tech is really catching up real fast.
T1 pro is really phenomenal
storm913
No idea tho.
Tried installing the fill+ app, but issue still persist. So strange to have this weird issue with spotify. Spotify updated too.
Edit: fixed it by going to spotify setting and put never to enter car mode.
pylpoh
tried a few earbuds, common man reviews as shown below:D
1) sabbat ultra :
bad fit to ear/ bad blue tooth connection / sound is ok
Generally speaking this is the worst amongs the 3. i wont dont buy it again. Bluetooth connection gave me alot of headache.
2) Truegine 3 se:
fit nice and tight into ear/ good bluetooth connection /sound is ok
Sometimes bluetooth need to be reset. I like the sound from this the most.
3) galaxy buds +:
nice fit into ear/ PERFRECT no ******** bluetooth connection /sound is ok
My everyday use now. Long battery life and i had no problem with the bluetooth. The ambient sound function is good as well; need to know when my baby boy is crying. Only problem is the low ipx rating; so i dont use it for exercising.
Converged
Any good earbud to recommend < $50 for running - good fit, sweat-resistance?
Posted from PCWX using koizumi's cat gifs
Yua Mikami
i find my taotronics 79 quite soft compared to the rest
but worth hooting?
storm913
lmao no give chance
:s13:
i believe you can't do that yet since it isn't supported?
been using the china version of the app instead.
The China app was causing issues with my phone, lagging and draining battery. I've uninstalled it and now all is working well. Is there a way to enter gaming mode without the app?
pathfinder6
A few you can consider
1) QCY
2) Haylou
3) soundpeats
I second this suggestion, so don't mind me adding on
1. Qcy T19
2. Haylou GT1 Plus
There's also the xiaomi air2 se that scarbir strongly recommended, but it's like shooting blindfolded buying from shopee. Not sure if anyone here got it from AliExpress
Vulpix
Moderator
Moderator
Just force close the app when you're done using it, I don't think there's a shortcut to gaming mode outside of the app.
Shawny88
lmao no give chance :s13:
Ok la. Tried the mic. Soft to the receiver but still audible. May be just need to speak slightly louder.
Ya, dl the china version app instead. The ANC really is cmi
Darkshadows
Comparing Creative Outlier V2 to Fiil T1 Pro, can anyone tell me which is better overall?
DigDub
Another pair of inexpensive tws earbuds. Coopidea beans air. Now on promo at Popular, $54.90.
Full controls are available, including playback/pause, skip forward/backward tracks, volume up/down and even manual power on/off. Either side of the earbuds can be used while the other one is in the case and the sides switch instantly without pause. The left and right channels are downmixed into mono when only either one of the buds is in use. The case is USB-C and is very small. The earbuds are small and comfortable too, it's shape is reminiscent of the once popular UFO tws earbuds. It's rated at ipx5 and claimed 5hrs operation time from the buds.
Sound is consumer friendly, big bass, a tad grainy highs and mids are ok, overall relaxed sound.
I took a closer look at the box containing the tips and found that there are actually 3 sizes of bass tips and 3 sizes of balanced tips. The bass tips have a smaller opening and a more conical shape, while the balanced tips has a wider bore and a more tubular shape. Putting the balanced tips on, the sound becomes more balanced, the big bass is gone and the mids and mid highs open up and take centre stage.
The connection seems to be weaker than my other earbuds though.
Case size comparison with Samsung buds live case.
PsyClick
HI
Looking for recommendations for BT iems with the needs below. TIA
1. Good mic for zoom calls
2. decent sound quality
3. Good reliability
4. Below $100
looking out for BF deals as well.
pathfinder6
HI
3. Good reliability
4. Below $100
Using Taotronics sound liberty 88, stable connection and other party no complaints about sound quality during webex
