Darkshadows
V2 similar sq with V1? If yes then maybe just get t1 pro ba.
Rated 5* By so many reviewers
Yea after some research, seems like Fiil T1 Pro is the better one. I'm not very particular with ANC. Now I'm waiting for a good price cos I see people buying it at $70±. Feel imbal to buy it at a lot higher price. The lowest I see now is $81.99.
storm913
If no rush, can wait for good sale then buy, else the few dollars more is also worth it to test them out early! :s13:
guile
Every Tues midnight Shoppee has a Tech Tuesday $20 coupon off for min $50 spend. Previously they release it anytime of the day on Tues. Fastest fingers to get it.
ksksksks
just wait for it.
Try it n u will know how good =:p
Darkshadows
Wow thanks a lot for the tip! I'll wait and see if I can get it next Tuesday.
hkchew03
HI
Looking for recommendations for BT iems with the needs below. TIA
1. Good mic for zoom calls
2. decent sound quality
3. Good reliability
4. Below $100
looking out for BF deals as well.
QCY T10, so far good sound quality, got it at $35. Suppose to have 4 mic to help with call quality, but can't verify, but I do find their T5 to offer good enough voice.
DigDub
Use back my $39 soundpeats truedot again on my Sony Xperia 5 ii and find that they are a good match. On Samsung the bass sounds bloated. Sony phone has a lower bass output and is more mids concentrated. So different phones actually produce different sound signature also.
tohchr
for Samsung, did u turn on Dolby atoms? Try turning off and see if it sound better.
guile
Its like this in the Shopee Feeds. Follow Shopee Tech to get notified in the app.
Sent from Samsung SM-N975F using GAGT
Henabi
I am currently testing the top 10 budget wireless earbuds listed in shopee (under $20)
I will be giving my personal opinion soon
wizardmao
Anyone using Apple Airpods Pro with android phone? Which android phone? Any particular feature or function of Airpods Pro doesn't work on android phone?
DigDub
The siri won't work. Ear proximity sensor also won't work. If want to use the stem to control between noise cancelling and hear through, need to configure on an iphone the controls first. Playback and track skip forward and back works.
wizardmao
Proximity sensor does play/stop when remove or plug into ears?
Hows sound quality of Airpods Pro compared to say B&O Beoplay E8, Sennheiser TWE?
