Henabi
Ask you guys. I have a few pairs of lower end tws earphones; Awei, Mpow, and QCY. All has volume control function. When I press the Awei and QCY earphones volume control, they will adjust the phone's volume. But when I press Mpow volume control, I notice it doesn't adjust the phone's volume. For example if my phone's volume is max liao, I can still increase the volume from mpow earphones. But if the volume is max on the earphones and the phone media volume still haven't max, I have press volume rocker on phone to increase.
Is this normal???
Sent from Xiaomi POCOPHONE F1 using GAGT
Iirc Some of these lower end TWS earbuds have built in volume level, some don’t have
Toader
Hi need help, bought a pair of sony wf-sp700n in mid July, left side earbud cannot charge and not functioning in mid Sept. Sony replaced it with a brand new set end of Sept.
Now this new pair again having the same problem. Today went down to service centre, they agreed to give me a new pair. I scared having the same problem, requested to change to another model.
With some top up, they said will put up a request to change to wf-xb700.
Should I stick to sp700n or change to xb700?
Bought the sp700n for $149, they wanted me to top up $50 for the change.
TIA for any inputs
Change to the WF-SP8OON. Water resistance and long battery life. Also has noise cancellation but not as good as WF-1000xm3~
kazuki666
Oic. Because this is my first pair of lower end earbuds have built in volume control, that's why a little confused. Have to max out phone's volume first, then use the earbuds to increase or decrease to needs
cryn79
Hi all,
I have a budget of $40, can someone pls help to recommend a pair of wireless earbuds? thnks!
bryanvlo
Guys, I been maining the Hyperteks lately, and recently got started using my Outlier Golds again. (I changed because the connection on the Golds were a bit spotty). I realized that I like the bass on the Golds cause the seal is really good cause of the design. Are there any other TWS with similar design?
kazuki666
Hi all,
I have a pair of Awei T10C, QCY T4, Mpow Mbit S, which all fit your budget. Eventually is whether you like the sound, which this is the segment I feel very personal preference.
kazuki666
Mpow Mbit S definitely a great choice at price of $27.
I bought them based on scarbir review. haha
The stock in shopee is a little weird de, will randomly OOS and restock and OOS again. Its quite hard to complain for this pricing. :p
storm913
Hi, anyone having issues with FIIL T1 pro connected as car audio instead of normal Bluetooth headset? I'm facing this issue, but not sure how to fix it.
