Nakedtoes
Hi all, if soundstage and audio quality is utmost importance, with $$ well spent, what is the recommended bt ear buds?
Thanks for your advice.
Soundstage wise... soundpeat is not bad..
chesterqw
I tried the fiil t1 pro in public yesterday, the ANC does quite a good job in cancelling out the bus engine/wheel/road noise. So it isn't as useless as reviews have said it is.
Obviously it isn't going to cancel out voices, even the airpod pros have problems with voices.
ksksksks
Bought another set of t1 pro :s12:
ksksksks
A comparison between my 2 fav earbuds
The Anc can’t fight with APP tho :D
I prefer t1 pro during run and app while commuting or working
Computeron
i'm wonder hows t1 pro vs sony xm3.
since i;m using xm3, n i keep seeing u all hooting t1 pro... makes me curious.
Nakedtoes
U on anc.. The sound quality got inpact?
Vulpix
Moderator
Moderator
I still don't know if it's my buds spoil or what, but the voice quality really cmi. :s13: Can hear, but it's not very clear to the other party.
pathfinder6
Anyone bought from shopee seller bigselina before? Upcoming flash at 23:00, deciding between t1 pro or edifier nb2
guile
Received the H1 today. Sounds not bad though the latency is noticeable while watching YT on my Exynos Galaxy Note 10+. Turning on Gamemode does help alot. Latency was much better when connected to my older Snapdragon Sony XZ Premium. This latency issue with Exynos chipset phones was explained by Kenneth though.
Tried connecting to my old laptop (BT4.1) as well, again latency is noticeable without Gamemode enable. But lucky can use Kodi and adjust the sound latency to match when watching movies or tv series.
In terms of sound, I'm not an audiophile and I've only listened with a Haylou GT1 XR, this was much better sounding and goes very much louder at maximum volume.
The case is also much bigger as well, inside the extra grey casing there's a slot to keep the USB C cable provided as well. Wireless charging works fine when I tested the wireless sharing via my Note10+.
Pairing is pretty straightforward too, you will only see 1 device in the list of Bluetooth devices. The passive noise cancelling works pretty well even at 50-75% volume and especially so when you use the supplied medium size Comply foam tips. I have yet to test it out in public places where it is noisier and have more RF interference to see if there any breakups.
Is it worth $100+, yes if you pair it with the right devices and use it for listening to music mostly where latency wouldn't be an issue.
