evilduxy
pathfinder6
Anker Soundcore Liberty Air 2 just arrived via Amazon US, anyone currently using it?
Contemplating returning it and getting Edifier NB2 instead hmm
Edit: the box is crazy huge, compared to the packaging for the likes of Taotronics, Haylou, Qcy, Soundpeats etc.
ksksksks
Just bought it from Westgate stereo
Loved this sony wh-1000xm4. Is there the updated earbud version?
DigDub
How is the fit and battery life?
I tried one (forgot which brand) when I bend down and take things, the ear piece drop out. :o
Fit and comfort is excellent. There are 5 pairs of ear tips inside. But everyone's ears are different, so what may be comfortable and stable for me may not be so far you.
chesterqw
Wish they included that many eartips with the old one... Only had 1 default pair for me cuz I bought very early.
Nakedtoes
Anyone has Fiil T1 pro and Soundpeats H1 which is better sound or buy?
Better sound is all subjective to yr preferences. I have the H1 and yet to try the fiil. But base on mine observation the fiil is the better buy. Could be better sounding also with the price. H1 at abt 110 is one of the best sounding tws I heard. The connection is so much better as it is using bt5.2. This can be compare with 3se(i own) using 5.0..
Nakedtoes
U can use back the old ear tips that suit yr ears.. I been only using jvc spiral tips for all my tws and Iem. Like this I can compare the SQ the most accurately.
DigDub
Actually I used back the tips from v1 on the v2, I find that most comfortable and seals best. :o
