xonix
- Mar 24, 2001
I revised my original post in case misunderstandingSamsung buds live.
Less than $100 and $200
Can take a look at SoundPeats True Air 2... just that the battery life is average lol.Can anyone a recommend a non in-ear wireless earbud ( like airpod ) that has the longest battery life?
1) budget ( less than $100 & $200 )
2) battery life > sound quality ( for public commute & occasional calls only )
3) IP rating ( nice to have )
4) ANC ( optional ; not neccesary )
Yah...I did see that. Seems to be having good sales on Amazon SG.Can take a look at SoundPeats True Air 2... just that the battery life is average lol.
Lazada Singapore got sell but its better to check with the reseller on the warranty T&C first before you hit the BUY buttonAnyone heard of Soundcore Life P3? The review seems pretty good. It's supposed to be cheaper than the Liberty Pro 2, but somehow I don't see it released in Singapore.
https://www.scarbir.com/tws/soundcore-life-p3-review
afaik, most On-ear or non in-ear wireless EarPods and earbuds do not provide any form of noise cancellation, be it passive or Active...Can anyone a recommend a non in-ear wireless earbud ( like airpod ) that has the longest battery life?
2) battery life more impt than sound quality ( for public commute & occasional calls only )
It's fine. i don't need ANC.afaik, most On-ear or non in-ear wireless EarPods and earbuds do not provide any form of noise cancellation, be it passive or Active...
because without the ear-tip and going into your ear canal, the EarPods don’t seal to your ear canal and passively block background noise out.
So Far...the only on-ear wireless EarPods which provide some kinda ANC is the Samsung Galaxy Buds Live aka the Beans.
Battery life wise... is 8 hours (ANC off) & 5 hours (ANC on)
The casing will give another 2 additional full charges, so giving you a total of around 15 to 24 hours usage
Galaxy Buds Live case has wireless charging capabilities, which is Qi wireless compliant. You may also top up the case directly from your Samsung Galaxy smartphone via Wireless PowerShare.
Been trying Fiil T1 lite for a couple of weeks now. For its price it's not bad, soundstage is wide, and it fits well and is waterproof. Bluetooth 5.2 connectivity is quite stable, and range is good.Anyone happens to own both Creative Outlier Air and Fiil T1 Lite?
I have been using Outlier air for more than 2 years, and I wonder if this Fiil T1 Lite has better sound quality compared to the creative earbud.
You can also consider Ugreen HiTune H3. Ugreen SG will be releasing it shortly.It's fine. i don't need ANC.
It's out of my budget anyways lol
U should try tronsmart onyx ace.Can anyone a recommend a non in-ear wireless earbud ( like airpod ) that has the longest battery life?
Your budget is under 100 or 200?It's fine. i don't need ANC.
https://www.tronsmart.com/products/tronsmart-onyx-ace-true-wireless-bluetooth-earphones
New product eh ?You can also consider Ugreen HiTune H3. Ugreen SG will be releasing it shortly.
Info page in China: https://item.jd.com/100013494453.html#none
Looks good, did you back it for super early bird?Anyone going to back this?
https://www.kickstarter.com/project...ref=ksr_email_user_followed_project_finishing
It doesn't shows what audio codecs it supports. So a bit hesitant.Looks good, did you back it for super early bird?
You can also consider Taotronics. They have one gradient blue buds with excellent mic quality.New product eh ?
I will check out reviews first
When are you posting your review?Go see the thread lah, @leecming bro already posted his review liao.
