DigDub
Also, considering $179 is just tens of dollars below the famous XM4. Would it not make more sense to get the tried and proven XM4 instead??
Ya can consider getting the xm4 since the price to c700n not much now. Maybe can try at Sony Westgate.
ZacharyA
Airpods pro or wf-1000xm4
Speaking of Airpods. I just got myself an iPhone 13 Pro Max recently and I always welcome the idea of an Apple eco system for convenience. But I don’t believe they are really that good earphones, and even if they really are, the price point is on the higher side.
I would prefer something I can use for long hours, can recharge fast, and ideally has lots of juice in the battery case.
My fiancee has an old Air Pods gen 2 and I’ll use it to take calls from my iPhone, and use the Sony one with my laptop for normal work.
xRenol
Any recommendation between Edifier T240TN and Creative Zen Air for running and commuting?
I am aware that they are not under the same price range.
Thanks.
tckrto
Thanks.
Creative outlier free not bad for running. Is bone conduction type. Now 79 bucks I find it good buy for running.
Henabi
i would say the airpods pro is justifiable
But definitely not the regular airpods
Long hours? Creative outlier pro
Probably can go like 13-14 hrs straight
waterballoon
if anyone is looking for the high-end ones, I recently got a pair of Bose Quietcomfort Buds II to replace my AirPods Pro 2
AirPods Pro 2 has much louder volume (At 25% is enough for me), but Bose QCBII I need to go about 45-50%.
Other than that, I prefer the Bose - sound is a lot fuller and wider, you can hear separate instruments like guitars, synths, etc. AirPods everything is very flat; so this is likely because Bose QCBII default tuning is somewhat V-shaped but I believe it's the hardware too :)
And AirPods obviously the connectivity and ease of use is unbeatable but I am more for sound quality
Henabi
i have very similar thoughts when comparing airpods pro 2 to sony wf-1000xm4
Audio level goes to airpods pro 2
But overall sound quality wise it is wf-xm4
ZacharyA
Thanks for the feedback.
Btw henabi, your username sound very familiar, must have known you from other threads many years ago,.
Anyway, I am using the regular air pods 2nd generation (spare set from my fiancee after she bought the air pods pro). Previously I was an android user and was using the razer hammerhead wireless earbuds. The connectivity is very poor and after walking away for few meters the connection will break and unable to continue with calls / music as compared to my dedicated platronics ear phone.
Henabi
For indoor usage…
The BT connection is heavily affected by the thickness of the walls and the amount of metal inside the walls
And base on my testing, this affects all wireless earbuds regardless of price
this is the same logic as indoor wifi.
if you are in the apple ecosystem, you can consider to upgrade to airpods pro 2nd gen
peaceheart
Platronics..... Very long din hear this brand, nearly forgotten
Had a platronics earpiece a long time ago before tws are the normal
Henabi
My simple verdict on Creative Zen Air
Would i recommend it?
Only if you are looking for the most affordable ANC wireless earbuds with the best sound and best mic and comes with wireless Qi charging
why I would not recommend it?
  • Weak ANC
  • Charging case has Short battery life
  • No app support
  • Use BT5.0
  • not the loudest earbuds
FlyGuardX
  • Weak ANC
  • No app support
  • Use BT5.0
was deciding this with QCY HT05. end up buying HT05
peaceheart
Same haha! My very first bt earpiece for calls
You still have it? Think I thrown mine away, the surface kind of "melted" and become sticky. Mine is this kind. It was ard $50 and very advanced even for today's standard. Rmb there will be a battery update whenever it is on
peaceheart
Weak ANC
No app support
Use BT5.0
Sounds like a bad product cos even the price is not exactly competitive
luei74
  • Weak ANC
  • No app support
  • Use BT5.0
Got a few BT5.0 hanging around, very consistent signal drop under crowded places
Henabi
mine was the M70
During covid, I wanted to re-use it... but the plastic become sticky and it cannot charge anymore, so throw away
