Raw power in what senseI have the Gemini 2 as well as Pi8. You want raw power Gemini 2. If want balance and details Pi8. Both are good.
Hows the anc of the pi8 compared with devailetI have the Gemini 2 as well as Pi8. You want raw power Gemini 2. If want balance and details Pi8. Both are good.
The sub bass. The dynamics of the sound. No one comes close to Gemini 2.Raw power in what sense
Both about the same. If compare to Bose ultra. I would say is about 75 to 80% of ultra. Pi8 needs to have better seal to work well. Gemini 2 not so particular about sealing.Hows the anc of the pi8 compared with devailet
Jaben should have.May i know anyone know any shop that available to test denon perl pro,pi8?
Pi8 can drop by at TCA at Adelphi.May i know anyone know any shop that available to test denon perl pro,pi8?
Whats your budget?Hi, can recommend best for call quality in mrt noise? Currntly using airpod pro with iphone.. other party have problem hearing me during calls… they told me the calls is choppy with high pitch noise etc…
ive seen some reviews from youtube about oneplus buds 3, nothing ear 2 etc… seems impressive but the test are not in the mrt.. so my main priority will be mic call quality in the mrt cause i travel in mrt most of the time answering important work calls… and also must be able to pair with my iphone of course..
Up to airpod pro 2. Lower the betterWhats your budget?
recommend to search online to check mic test reviewsHi, can recommend best for call quality in mrt noise? Currntly using airpod pro with iphone.. other party have problem hearing me during calls… they told me the calls is choppy with high pitch noise etc…
Check emeet airflow.Up to airpod pro 2. Lower the better
Check out earfun air pro 4Still using the Fiil T1 Lite for my phone+ youtube watching while lying on bed.
Tried Creative Outlier Air V3, overall sound is nicer and richer, but gave it up as its not as responsive and always have issue connecting to phone.
The Fiil T1 Lite immediately gets recognised and I always only use one side of the bud, it'll almost instantly gets connected to whichever I pick out from the case, and sometimes change side as I replace it back and pick the other side up it also get connected immediately.
Is there any other buds out there that can improve sound quality but still give me the immediate connection to my phone?
totally agree… nowadays its common to find some of those so-called “Premium features” on those sub 100$ TWSSoundcore Liberty 4 Pro released without much fanfare. SG retailing for $199 but able to find export sets going for ~$160. Impressive specs but with the sub $100 segment being so competitive, hard to consider paying a premium for supposed better specs which you may or may not need.
