also someone mentioned vstarcam problems with Asus N56U routers? Marix can comment? were the issues resolved?
just got a set of the VStarcam H6837WIP. there are so many settings in the super client, for extra fine tuning of video vs wireless performance, which is the most optimal setting? for phone as well as PC viewing.
Video size - 320 or 640?
Video quality - #?
Bit Rate - Constant or Variable?
Bit Rate - 256 or what other value to set?
FPS - 3/7/15/30?
Pls advise if anyone knows
P.s. do I need a permit to put security cameras outside my HDB flat?
For VStarcam T7838WIP would be better, it will be a bit not so smooth as compared to H6837WIP, but can adjust down the bitrate to overcome this. Default bitrate was set at 4Mbps, I would suggest to down it to 1Mbps. I did that and I can watch my streaming better on my iphone n android.
T7838WIP will be better in terms of its mobile APPs. Can record to iPhone during streaming. Something the H series can't.
H6837WIP would be good if your home internet cannot have that bandwidth and you need to mount. So, you should consider that when you purchase.
Looking for recommendations for wireless security camera to mount outside my house..recently got some bugger decided to steal my family's clothes and undergarments. It has gone to the extent of even stealing the whole bamboo. (Just a heads up, my bamboo sticks that are outside my house is legally placed and secured. Not hanging precariously)
So I've decided to place two cameras at two strategic positions such that the bugger will be caught when leaving the premise but wouldn't notice it when walking in the one way corridor.
Please do recommend a relatively clear video footage IP camera so that it can record to my PC. I have teras to support the size. Sound not that important.
Camera should also have the ability to adjust after mounting. And best if can monitor from my computer or even better from my android smartphone.
Looking forward to all you gurus for recommendations!
Hi Peeps,I am using T7838WIP. Everything seems fine after the PNP. However when i uses my Iphone to view via 3G/4G network, there's a red wording on the bottom right. It says relay mode and there is a countdown timer. Any way to fix or everyone using has this? There is also a lag time on the image compare to wifi connection.
T7838WIP new firmware has come out.
