Working Shoe for Young Exec - Part 2
Bluebird33
The obvious choice is enzo. Their chelsea boots are even wholecut.
I can't believe EEA charges 3000 for that crap. Their outsoles for bespoke aren't even hand stitched.
You can almost go jap bespoke at that price, if you know where to look.
Looks like have to go MTO route for Enzo..
I think hiroyanagi charge around that price.. Others slightly more.
nethdale
right size, wrong fit i guess.. breaking in is PITA, felt like i was wearing clogs :s22:
Meermin leather is really hard, now exiled to my storeroom
Indeed Meermin's leather is hard, since Jan 16, I am breaking in my Oxford with Hiro(??) last, still I feel the stiffness of the leather. Luckily, they recommended 1/2 size bigger due to my width of feet. If I took the right size for snug fitting, I will be also retiring the shoe. I am unsure my next pair with Meermin should I stick to their recommendation or my usual size. Very painful la.
noobzpro
Vass cordovan is about 10-15% cheaper than Carmina depending on your sources
But while handwelted, may have some production liberties, since each craftsman basically otot.
Cant beat the colour range of Carmina's cordovan selection though. Clicking wise I think Carmina is even superior
Hey bro, are there any store in sg which offers vass? Thanks.
likehotbutter
Got local distri. Holdfast Fine
They have some RTW stock that is priced very reasonably.
But if you do MTO then that's where most of their cut comes in so would be pretty hefty and may not be cheaper than Carminas.
If you're looking for cordovan dont think they have rtw stocks.
likehotbutter
Pre set/Guide creases with a pencil
Wear and walk about for 10 mins to settle crease
Condition and brush the heck out of the flex areas.
That's my shortcut if it helps
terras14
Haha what abt 42.5? I wear 43.5 myself in case you think I'm trolling.
My goodness how long have you been wearing your shoes for and who the hell told you it will take 2-3yrs to break in? Visit a cobbler to stretch the damn shoe for goodness sake.
Sent from the exploded Death Star using GAGT
Meermin well know for stiff leather. If i only wear once a week, i think i take yrs. cannot be wearing everyday esp if that day i need to be comfortable and i meed to rest my blister too
noobzpro
Thanks a lot bro. I also require a normal leather shoe so maybe can consider haha. Actually really liked the skoatie mto for enzo bonafe side laced but the top part suede haix.
WakeUpDead
I read up a discussion on styleforum, you can actually accelerate the time for breaking in. Use a metal stick, press down on where you want the creases to be and flex the shoe accordingly.
I found that it helps to retain the aesthetics of the shoe and also prevent the creases from forming on weird areas leading to rubbing on other parts of the upper part of your foot.
My meermins are still stiff as ever but the parts where the blisters were at do not hurt anymore. Could be due to a thicker layer of skin forming over, but i like to think that this method helped at least a little?
The ankle heel part cant be helped tho. Thick socks and plaster!
thundermarch
Am sorry. I was actually the one who organised that gmto.
My initial thought was calf / scotch grain. But eventually went with suede due to another participant's preference.
