maxell_555
- Feb 8, 2009
Try heel inserts? If slippage is at the ankles then may not be able to resolve.
Ahh.. That's a classic example of why loafers are so tricky to buy online. There are two possibilities here; stand up with your loafers on and try to lift the ball of one foot up, does the shoe still stay snug on your foot, or does it slip off the heel and come off ? ? If it's the former, then your loafers have to be broken in and the slippage should lessen with time. If it's the latter, then you've got the wrong size and should read on..
Generally, try to go down half a size from your lace-ups for loafers. The first priority should be getting a good snug fit at your heels before you determine anything else. Heel slippage gets worse as the shoe breaks in and stretches; I have some pairs that went from "manageable" to completely unwearable after a few weeks. If you find that you have to size down too much(so much that it crushes your toes), then the shoe last is simply not for you.
Loafer sizes are a hit-or-miss thing unfortunately, I have maybe 6 pairs but I only own one that fits me well. Coincidentally, the first time I got my fingers(or toes) burnt buying shoes online was with Alden tassel loafers
Heel grips and insoles help a little bit, but your best option would be to explore other sizes or brands/lasts.
I would try a little longer tmr. Can y'all show me pics and brand of heel inserts/grips that you recommend? I have tried insoles but just tightens the front foot yet not help the heels.
