xbmc live tv
ricardoo
Hi
Does this require any hardware? if it does need hardware, that means it can't be installed on an android tv box?
Hope some information of set-up guide help.
1. Download NextPVR Downloads | NextPVR
2. Install NextPVR and setup your tuner. Use the wiki here if you need any help setting up the NextPVR software. NextPVR Documentation Wiki | Main / NextPVR Wiki
3. Test NextPVR. Make sure that you can view channels in nextpvr.
4. Download XBMC Frodo. Download | XBMC
5. Install XBMC Frodo, make sure that you install the PVR plugin for NextPVR in the install options.
5. Stop the NextPVR services using the shortcut in your start menu under nextpvr. Make sure the dialog box Stopped appears and click ok.
6. Download the updated dll file http://forums.gbpvr.com/attachment.php?attachmentid=36068&d=1364084249
7. Extract the nshared.dll file into the NextPVR folder in your Program Files.
8. Download the updated XBMC plugin from here. http://forums.gbpvr.com/attachment.php?attachmentid=36068&d=1364084249
9. Extract the dll file to the Program Files\XBMC\Addons\pvr.nextpvr
10. Start NextPVR services.
11. Go into XBMC, go into system\settings\live tv & enable, choose the nextpvr and click enable. Job done.
Jeffsrightnow
Hi
Yes it does require tv tuner hardware but not suitable for andriod device.Most andriod device use IPTV with m3u8 playlist:s12:
Jeffsrightnow
New Launch Andriod Box
Quad core 2G Ram 8G Rom Android 4.4 XBMC Skype 4K Android TV Box RK3288
1 CPU: RK3288 Quad Core up to 1.8GHz (Cortex-A17) .
GPU: Octa core ARM Mali-T764 GPU up to 600MHz
2.supports ultra 4k 2k ultra HD decoding and output (4k2k H.264 Video Decode and 4k2k Output);
3.using the latest Android Google Android4.4 Kitkat;
4.DDR3 2GB, 8GB/16GB ROM on board,Hardward 3D Graphics Acceleration
5.1080p hardware encoding (1080p Hardware Decoding @ 30Fps, HD Live Chat Available);
6.chip supports dual 1080p decoding, is developing PIP function (Dual Chanel HD Decode, True Pic-in-Pic Experience).
s7460597
How much does one cost and how to get it? :D
s7460597
Seems qoo10 has a seller for rk3288 measly box S$145 including postage. Seems quite reasonable.
Jeffsrightnow
This seems good as well as it embedded with powerful quad-core GPU ---Mali-T764,is the highest level GPU among ARM Mali series,It has the top graphic processing capability.
And custom Rom wise will take some time to develop.
Winsbchua
Can your box be used to view live CNN, BBC, CNBC and EPL? I have a 2 year old androud tv box but seems like cannot work as of last week to watch CNN BBC
Jeffsrightnow
You can try install IPTV repo on page #51 as for EPL you can use Navi-X look for sport tv Hd channel choose test channel it work for Epl yesterday match.
