Xiaomi Box Android TV Box
asriznet
install speedtest.net apk in the box and run a test using the default singapore server. If you can get more than 10Mbps then you wifi is good enough.
Precisely what I was saying, getting 90%-100% of my 100mbps plan on wifi using ookla speed test to local server.
USB to Ethernet getting 50mbps only, throttled by the adaptor.
plasticpistola
Clarence80
ok guys, i have successfully rooted the box but however still unable to sign in to playstore.. keep getting the message "There was a problem communicating with Google servers", i have installed and ran the 谷歌安装器 and no errors were reported..
not sure what am i missing?
silentscope
Hi all,
I am using 网趣云加速 for China VPN, this program gives me 2 months of free trial.
However it is ending soon.
Do you all have problem streaming Chinese drama, especially from youku, pptv that are block in Singapore? if you all does not have a VPN, what do you guys use?
I saw there is a Youku破解版, does this require VPN?
gregory_choo
Hi all,
If you use the right apks, you can stream drama/movies from china servers smoothly without using VPN. Youku破解版 is one of them. But it has many versions, not all work properly.
silentscope
the Youku破解版 cannot work once i dc my VPN.
Can you share that version APK~
I really think it is hard to enjoy xiaomi box without VPN. However even with the trial VPN, it is not every time reliable too.
Zzzz
iTrexboy
anyone know why the streaming slow n sometime hung when I'm using fibre ? Is it the server prob or the router???
gregory_choo
Zzzz
There are a few version of Youku破解版, some already expired.
install the 电视必备 in shafa market, then click on youku in 电视必备. This version is good.
zheyan
you guys bought the mibox from Qoo?
can recommend any sellers?
i bot from Lazada when it's offering $85... Ordered on 30-Dec-2014, arrived this Monday 12-Jan-2015, but now I'm considering to sell off cos thinking of getting Amazon Fire TV just for the full English UI OS.
cherryjiyong
Instead of Mibox, I bought a Jesurun from kingsbuying.com. It seems not a quite well-known Android TV box, but works like a charm. I spent about $96 on it. Or you can check it out if you need Android TV box.
jesurun-dx05-quad-core-android-4.2.2-google-tv-player-w-2gb-ram-8gb-rom---black-_-silver-_eu-plug__0.jpg
silentscope
THanks! after testing abit.. The Youku破解版 can really stream well without VPN.
However got some new movies is under member.
But lucky got all other good apps.
THanks
Clarence80
Anyone had similar experiences?
Thank you!
CanonG
I saw a lot of mibox 4k on qoo leh..
how to differentiate fake mibox 4k and real one?
asriznet
Thank you!
Which method of Google playstore installation did you follow? Was it using the Google Installer app?
I think I encountered it before when I did it myself a few times, it was quite random. I don't remember what exactly fixed it but these are what I tried...
Uninstall all the Google apps
Forget wifi network(I use Unotelly DNS)
Clear all cache
Reboot mi box
Connect again to wifi
Reinstall Google apps using the installer
Other suggestions would be using Google Public DNS on your network: 8.8.8.8 , 8.8.4.4
