Xiaomi Box Android TV Box
Just Me
means XBMC got NatGeo, History channels, etc and can watch entire seasons of Supernatural, for example?
Also got TVB series and HK movies in Cantonese?
I said VOD, didn't i? For streaming channels like you mentioned, you can try hdp or sub a service like qyzb, season etc...
plasticpistola
Just Me
XBMC has addons like genesis which has the best selection of US movies and dramas.. but you need to source around to optimize xiaomi box with xbmc as mine's himedia. But if you are not sure just pay the seller to install xbmc for you..
Qyzb works with mibox.. you can PM me for the apk should u need to try out as it has 5 free trial channels.. of course you can get all free channels for 30 days after requesting for it in their qq group..
all this i'll be able to do via the mibox? paiseh leh, i damn green in this :(
maige tv have but too ex leh - more than S$400 :eek:
plasticpistola
ok, got it! thanks, bro!
Clarence80
check with you guys, i have installed shafa market yday and was testing out the inbuilt network speed check, the speed was real bad and even downloading updates like chrome also took like 30 mins
my box isnt "rooted" yet so cant use google playstore yet but not sure if it is the cause, i have also restarted my router and tested my internet speed, everything is as per normal..
any advise if theres something i'm missing out?
lastly, by resetting to factory defaults, it should clear up and return to the out of box condition right? (i got it from the lazada seller, so nothing special pre-installed)
thanks all!
oho
Can anyone advise as to which brand of usb-to-RG45 (ethernet) will work with the xiaomi.
I have tried one which does not work. Thanks.
asriznet
Erm I just got a cheap USB 2.0 one from bizarre however the speed is much slower than my wifi by 50%
thanks all!
Those speed test are linked to China server so it's expected to see slow results. To test local speed, you can install Ookla Speedtest instead.
If you want a faster connection to China, you may need a China VPN service.
Yeah the box from Lazada is not preconfigured with any additional software.
You may need to boot to recovery to restore it to factory.
oho
Thanks asriznet.
I think the adapter has to be made for android devices.
Many of these usb to rg45 adapters are more for pc.
Clarence80
i'll try that speedtest when i can, tried to install playstore last night but failed, didnt know i had to root it first before i can use playstore
I did speed test on WiFi also. The speed cmi but streaming still OK. I set to HD and not fhd. But I didn't stream for long to test though.
Best way usually is to use VPN bah.
Sent from Underwater using GAGT
i havent got a chance to try any streaming yet, was trying to get the basics done, like playstore, rooting etc. any recommendations on streaming app from shafa? i'll try again tonight! cheers all!
gregory_choo
I have posted recommendations here:
https://www.facebook.com/groups/373915026119266/
plasticpistola
asriznet
Thanks asriznet.
Hah, I think I'll just stick to wifi rather than investing on another adaptor.
Am already getting 90%-100% speed via Wifi anyways.
plasticpistola
gregory_choo
install speedtest.net apk in the box and run a test using the default singapore server. If you can get more than 10Mbps then you wifi is good enough.
