Xiaomi Box Android TV Box
ragegoh
What is the 多云 icon about?
Sent from Samsung SM-N910G using GAGT
asriznet
Wonder if anyone got DramaFever App working on the Mi Box. The Google TV version don't seem to work while the mobile app does not work too well on the xiaomi box because of the interface.
HMAN
I have both mi tvbox 3rd gen and nexus player , with the context of self support getting China app to stream. I would say mi box is more flexible.
Performance wise, no visible difference
Without rooting
Mibox + wireless mouse+ 3rd party launchrr, you can control TV built app and touch Base app easily.
With mouse, no button is mapping to menu key , there is slight inconvenience
Nexus player without rooting
Mouse left /right click function as select ,no mapping on menu ,back
Remote control: no menu key
To get everything to work, one need to use those mouse and keyboard combination.
Hope this helps those that deciding what to get.
Sent from Motorola NEXUS 6 using GAGT
buaians
Anyone upgraded from Mibox 1 to Mibox 3?
big difference in performance? not sure to spend another 100+ for upgrading
lindalimhl
I'm using 优酷 to watch korean drama but I have noticed that 2015 dramas cannot be found. anyone know why?
PatrickL33
My sugoideas stop working on kodi. Script error. Most of the options on empty empty updates can view few items. Any idea?
masashi
Can I just check if I see the 4th Gen is actually the enhanced version? Was told there's a 2gb ram version too.
wwf
So get the mi box 4k or mi box mini better?
Anyone test out AirPlay function
Is it good?
So guess order from Tabao better right?
galliano
Any idea how to stream YouTube vids frm iPad? I suspect it's cos I have no YouTube on the mibox.
It's built in "airplay' functions works well with the iPad's video players.
galliano
Struggling to access Google Play store.
but always stuck at the signing in. Error msg 'problems communicating with Google server'.
ekardo
download apk and install via thumbdrive..
I have the same prob, either the set still think that I am in china, or mine is a rooted set...
but I am happy with shafa and qyzb...
chengsun
can I confirm that, the latest mibox, 3rd gen, does not have a RJ45 port, must use a USB-to-RJ45 adapter?
chengsun
anyone know why suddenly taobao xiaomi no more selling mibox? also, the other 3rd party sellers, all want to sell jailbreak version or so called with extra channels for extra cost, if want mibox only original prices, must wait 60 days!
masashi
I just got mine unadulterated one from Qoo10, arrived within 2 days :) shall set up after work tonight.
Sent from Kanoya Naval Base using GAGT
