Xiaomi Box Android TV Box
asriznet
How do I install to external sdcard? My internal already full Le zzzz
micro sd card slot is there so plug n play?
Unless you want to change sd card as primary storage.
If I remember correctly, you need to activate developer options then from developer options you'll see in the storage section to use sd card as primary storage.
You'll need to format your sd card as FAT32 first.
Seems to work when I installed a large size game which didn't work without the SD card.
If you want to learn more, search for app2sd and link2sd, lots of information about those online.
miboxowner
Hi all, i just bought a Mibox. I have installed some of the apps. Many apps needs a mouse pointer. XBMC also need a pointer or else some spot cannot b selected. Many apps are useless without a mouse pointer
anyone have any idea how to connect a bluetooth mouse to the mibox? i seen in this video that mibox mini can connect to a mouse, at minute 1.35:
( i cant post link, so just search "Xiaomi Mi Box Mini review" in youtube)
Best is if my phone can connect via bluetooth as mouse, can save money and hustle of buying a mouse
asriznet
Rather than get a Bluetooth mouse, better to get a Bluetooth keyboard with trackpad like the Logitech K400.
Works perfect on the Mi box - makes it easier to type.
CyberMew
Thanks for the information. I managed to enable the developer options but I do not see any storage section in Developer option for me to set the default storage. Any idea what's wrong?
miboxowner
Sorry I forgot to mention that its a Mibox mini. U know if this will work as well?
asriznet
The default launcher won't give you that option. You can access the developer menu using XH Home TV launcher.
I believe the mi box mini does not have a USB, OTG port so the Logitech keyboard will not work. You'll need another device that connects via Bluetooth without a dongle.
kryptonie
anybody have their mx player crash when playing some video using hd/ thumbdrive it will crash every 20 sec.. isit the setting issue ?
gregory_choo
if you need mouse/keyboard, mibox mini is a wrong choice. you can only use expensive bluetooth mouse/keyboard. although the box is slightly cheaper, the final cost is much higher
Better stick to mibox 3.
miboxowner
Thanks . I have bought the mibox mini. didnt anticipate this problem . it got paired and connected to my bluetooth mouse, but no cursor out. even redmi note can work on the mouse. i am now a very dissappointed mibox mini user.
Thanks Asriznet for your reply too
asriznet
I think the mi box mini is a decent device for streaming contents using apps that are made for an android TV box - maybe for use at hotels while on trips.
For other heavy usage like gaming is probably not a good idea.
Most of the apps that don't work well and requires a mouse usually because it's using Android mobile/tablet interface.
Do update us how the performance is like on the mi box mini. 1 thing I like it over the older mi box is the remote control, I believe it's using Bluetooth instead of infra-red.
miboxowner
i got my BT mouse to work (after changing Toshiba to Logitech).
My other problem is keyboard. If go Youtube, the Android keyboard do not automatically appear.
Btw, today got one Mibox update. after the update, it appears the google play and google setting is not able to work anymore. it appears to be blocked
asriznet
So the Toshiba mouse was not compatible uh...
Yeah an update did broke my google store which is broke the framework in HDExposed, just updating the framework fixed it for me.
The YouTube for GoogleTV app works perfect on my mi box with the remote, better with the keyboard for easy typing.
Genkunzz
I just got mine unadulterated one from Qoo10, arrived within 2 days :) shall set up after work tonight.
could you also share the seller name to me???
Will like to buy one without the modding. Thanks
SwaKu
Lazada seller still selling them - (EXPORT) XiaoMi Mi Box 3 Quad Core Android 4.4 Smart TV 4K HD Box | Lazada Singapore
Latest Mi Box model(stock set)
They have been increasing the price slightly because of the demand I'm guessing. Was $85 back in December.
Hi asriznet,
Is this vendor a reliable one that sells the real Mibox (not fakes)? Do they help us to load in the popular apps so that we can start streaming videos once we get it? Sorry for the questions, been trying to look for a decent vendor to get a android box but not sure which one to get as I heard got fake Mibox in market. Don't have to be the cheapest but reliable is more important.
Do I need this as well?
Mele F10 USB 2.4GHz Wireless Remote Control Fly Air Mouse Keyboard 3-in-1 for PC Android TV Box (Black) (EXPORT) | Lazada Singapore
Thanks.
oddbasket
Hi asriznet,
I bought from that seller on 19/2 and it arrived yesterday 2/3. It's the real deal, Mi Box 3 with 1GB ram. It comes with only the stock OS and launcher plus a few pre-installed apps, barely anything on it. Note that it is completely in Chinese.
You can easily copy apks linked by the bros here onto a thumb drive and install onto the Mi Box 3, then start using those apps to stream.
SwaKu
Thanks for the confirmation. Any way to convert it to English? Do I still need this for navigation or the supplied controller is good enough?
