Xiaomi Box Android TV Box
msaz
can anyone recommend a compatible remote control for xioami box one that boast tv like input like numpad
tckrto
Hola free vpn apparently uses your internet connection to do other stuff in the background. Flipboard tech news said users' bandwidth are sold by the company and can be used for spam attacks, etc. Better read up before using.
Whatever is posted on the internet is always true lol!
BigAssGun
High Honorary Member
jialat siol, i bought a mibox, but how to connect to pc and install custom app siol~? :eek:
lavive_gp
Hi fellow xiaomi box owners!
[question] Does anyone use TVMC app (a.k.a TV Add-ons = a custom package using XBMC gotham and preinstalled video add-ons)?
When I play movies or TV shows from Genesis / Icefilms /1Channel (whatever the sources chosen like 180upload, movreel, VK,...) the playback is interrupted every say 10 minutes :eek: especially in the evening and a stupid picture then another picture (advertisement) is displayed asking you to press up or down to like it or not, and if press down it displays 不喜欢的图不出现咯!
This is really annoying and I didn't find in Internet any answer to what it is due or or to get rid of these interruptions.
=?> Anybody experiencing this too with TVMC?
=?> Is there the same with XBMC Gotham?
thanks a lot for your replies ;)
Xiaomi box 3 / Starhub fibre over WiFi / no VPN
gregory_choo
Nothing to do with TVMC.
It is a firmware bug. xiaomi's firmware cannot detect that the movies is running, and the screen saver kicks in.
The way to go around the problem is to turn off the screen saver.
gregory_choo
The easiest way is to use a thumbdrive.
Can also use xiaomi's remote install if you are able to navigate thru the confusing menu.
You also can use shafa market to do remote install. Tutorials are in shafa's website www.shafa.com
lavive_gp
my savior :s12:
thanks a lot buddy! appreciated!
lavive_gp
Correct. All details (transparent) in their FAQ: hola.org/faq
then it's a personal choice to contribute to it and bear a risk.
Ramwee93
hi just brought the mibox, coming my house tomorrow but looking for
live channel any apps to recommend?
rk79
Hello all , i got my Xiao mi tv box last dec .I realize now most of the movie/drama (old/New) i played will prompt out a box saying can only be view in china .Can any bros guide me steps by steps ?
rerear
suddenly my Shafa is downloading app updates very slowly, like want to update MoreTV, it takes forever, anyone knows any known lesson?
In fact, now checking on the downloads within the Shafa, it shows the download is stalled. On latest version of Shafa 4.1.2.
adrian_4781
Hi all..3rd gen n 4th any hugh difference?
Qoo10 seller told me to get 4th gen..but it wit lesser port..
Pengsp
GG and see spec. If you cannot tell the different, then may be it is not important to you. Most android box specs are now a day more than sufficient for streaming the show. You might want to consider the one with larger storage as the OS itself occupied a lot of space. Most people will add Kodi app with lots of add-on and it will need some space for caching. Otherwise it might not run properly, e.g. black screen and only sound. USB port problem can be solved by adding USB hub. If you need the port for thumdrive, then just use remote feature in ES file manager and you can transfer file directly from pc to the box, vice versa. If budget is not the problem, I think 3rd gen might be better. That what I got for myself. The 4th gen need to plug directly onto the power point. I don't really like the idea.
Pengsp
Try using web browser to search for ES file manager, install, go to the left menu, Remote Manager, Turn on.
Go to your pc, start file manager, type ftp://_____ according to what said on the mibox screen. Now you can freely transfer file back and fort between the box and the pc. Don't even need to plug or unplug. Life is much easier:s12:
