Xiaomi Box Android TV Box
pclum
Hi fellow xiaomi box owners!
[question] Does anyone use TVMC app (a.k.a TV Add-ons = a custom package using XBMC gotham and preinstalled video add-ons)?
When I play movies or TV shows from Genesis / Icefilms /1Channel (whatever the sources chosen like 180upload, movreel, VK,...) the playback is interrupted every say 10 minutes :eek: especially in the evening and a stupid picture then another picture (advertisement) is displayed asking you to press up or down to like it or not, and if press down it displays 不喜欢的图不出现咯!
This is really annoying and I didn't find in Internet any answer to what it is due or or to get rid of these interruptions.
=?> Anybody experiencing this too with TVMC?
=?> Is there the same with XBMC Gotham?
thanks a lot for your replies ;)
Xiaomi box 3 / Starhub fibre over WiFi / no VPN
mine is same, When I watch the "San Andreas" by 1chennal, it stop and download, even u switch to other input and watch channel 8 and then 10 or 20 min can come back and watch, it will run smooth for may be 2 to 5 min and then it stop and download. I don't kwon whether it is something to do with the bandwidth or other .
ekardo
technical question;
I just uninstalled most of my apps, but my xiaomi shows me 1.7gb installed, out of 2gb...
and ES explorer doesnt allow me to see what is taking up that 1.7gb...what should I do?
also, after installing a few apps, I ran out of space to install liao... :(
mikehwz
technical question;
Mine too. Seems like I only has 2gb rom instead of 4gb rom.
nannan82
Got a small problem.... I realise nowaday most of the drama kanna block??? Any workaround?
eudora
why pay so much?
it is only $85 before discount from lazada. normally can get 10-15% discount if bought during weekend.
I thought the qoo shop selling 100+ with apps etc with root not bad? Does the lazada also install all the apps?
leeku
Pairing bluetooth
Hi, need help to pair bluetooth keyboard and trackpad (Apple) to my new mibox. When I try to pair bluetooth devices it can only detect my AppleTV and Mac. Are other Apple products like wireless keyboard not compatible?
gregory_choo
Most qoo sellers only "jailbreak" the box. Their meaning of "jaibreak" is installation of a few apks, not root.
All the apks supplied can be obtained freely from internet.
Effectively, you are paying $30-50 for the installation of these free apks.
eudora
Most qoo sellers only "jailbreak" the box. Their meaning is "jaibreak" is installation of a few apks, not root.
Ah ok thanks! Can anyone check if the box has variable voltage? Want to bring overseas and use..
ekardo
my question is how come the system take up so much space? 1.7GB...
and I can't seems to clean up...
am I the only one having the issue that the OS is taking around 1.7gb out of possible 2gb for apps application ??
galliano
Help.
Have gotten a mini Mibox from a friend to help him setup. Problem is he forgot to pass me his remote. How do i sync/tag my own remote with his box? The remotes are all bluetooth.
Mini Mibox no USB port, so cannot plug in a physical mouse.
gregory_choo
Help.
from miniliew' blog:
"Just in case that you lost the bluetooth signal. You can pair the bluetooth remote control by pressing the Home button and the Menu button and hold it for few seconds until you hear the beep sound. You have to hold the remote very near to the Mi Box mini."
galliano
Thanks bro. That worked like a charm.
mcmxcii
File formats
Hello all
According to Xiaomi's website:
"When playing videos directly from flash or external hard drive,
the Mi box supports multiple HD formats such as MKV, AVI, MP4, MOV."
... may I know if anyone here have tried RMVB too? Thanks.
(I've emailed Xiaomi Singapore Customer Service Center and their reply: "Not sure") !?!
