Xiaomi Box Android TV Box
lingcw
I just got my 小米盒子增强版! But donno is it i am hotel thats why cant stream any channel. Mine jailbreak already any kind sole can teach how to install 3rd party apps? Thank you!
Try this. It work on my xiaomi box 2, hopefully it work for your xiaomi box 3 too.
Copy the apk to your thumb drive.
Connect thumb drive to your xiaomi box
Launch “高清播放器” under the "应用" tab and look for your thumb drive (you might need to reboot your xiaomi to see the thumb drive)
Navigate to the folder where your apk is and click on it. The app should install.
tckrto
The new Mibox can use wireless to install apks just drag and place. Manage to install a numbe of apps but cannot install google play store.
bjory
After updating to latest firmware seems like storage greatly decrease. Can't seems to load in much apps. Anyone knows how to increase the storage capacity or can use USB thumb drive as alternative install location for apps?
lingcw
I think you need to install google services... not sure how though.
chickencow
Another way to install remote on Mibox 2 is by below method
1)【应用--应用商店--管理工具--远程安装】
2)it will shown a IP address to remote access the Mibox 2 via your PC/labtop web browsers on the same net work .
3)from the web browsers .. select the file to install ..
Cow
gregory_choo
I don't think so.
This is one limitation of mibox2. Small memory and not expandable. mibox2 don't have SDcard slot.
Some version of andriod allows memory card in SDCARD slot to store APK.
May be this decrease in storage is one method from xiaomi to let them sell more mibox3.
The mibox3 has 8GB and also a SDCARD slot.
Other brands has less problems.
titiju
I still can't install play store yet though. What I am doing is open up browser from MiniX Metro launcher, download the application APKs and install them on Mibox directly.
gregory_choo
a few steps to install playstore:
1. Root the box
2. Copy GoogleServicesFramework, GoogleLoginService, vendor apks to system folders data/app and system/app
3. Change the property of these apk to rw-r--r--
4. reboot
tckrto
All those people if you can't wait for Singapore to launch below is the source which my china friend buy from.
宇通佳音数码专营店
They up price recently. Use to be 449rmb
I am no associated with the shop. So please do not ask me anything. I only provide link for you guys. As for shipping kindly look for the taobao thread for clue.
lingcw
1. Root the box
4. reboot
Too chim liow... :eek:
But in case I do want to try, any idea where to download the Google Services Framework etc?
new64
bluetooth mouse / keyboard with xiaomi box2
hi ALL,
just want to check with u,
do u use the default remote control ?
or u connect a bluetooth mouse or keyboard?
which bluetooth does it support 3.0 or 4.0 ?
or u use a OTG cable with mouse over it ?
Regards
lingcw
hi ALL,
Regards
I use the default remote control most of the time.
Having said that, some apk works better with a mouse.
So on the rare occasion that I need it, I connect my normal laptop wireless mouse to the xiaomi box. This is by connecting the wireless mouse USB dongle to the OTG cable.
Somehow, I couldn't connect direct to the XiaoMi box inbuilt Bluetooth.
tckrto
hi ALL,
Regards
For mibox 2 dont have usb so need to use otg cable.
As for keyboard or mouse support i no too sure.
Bluetooth i think is 4.0
For mibox 2 pro have usb liao. It supports wired mouse and keyboard i tested it liao.
Bluetooth is 4.0 but i cant get it to detect my mouse.
bjory
I don't think so.
Since mibox3 have SDCARD slot, but not sure if the OS allows you to install apk in SDCARD or at least use SDCARD for some of the apps storage.
gxelan
GPGT
how much u get ???
