Xiaomi Box Android TV Box
iamlenon
anybody can recommend where can i get xiaomi box 3rd gen for a good price?
exclude qoo10 :o
tremor
Need help. I tried searching for answer in this thread but can't find.
Got a mi box 3, should be rooted cos comes with English interface and many apps. How do I watch Hong Kong shows in Cantonese? Chinese dubs really cmi.
eng11658
Btw i am looking for a tv box to watch mainly bpl and taiwan live tv.. Does this xiaomi version 3 work well? Looking for stability... and ease of use
Really need help...
lingcw
Don't think English interface means rooted.
Anyway, just install Youku. They have HK drama in Canto language. Just change in settings.
Kahlan
can i check, you guys on wireless or wired for xiaomi box?
Thinking of getting the 2nd generation as slightly cheaper, and using wireless. Any issues?
whoooo
i am using wireless when u meant 2nd generation becareful as xiaomi Mibox is 1, 1S and socalled Mibox 2 aka pro aka enhanced.
buy the Mibox 2 aka pro as I am using 1S and going to dispose it off as it is 1 of the slower box i have :s22:
gregory_choo
A perfect match =:p
Kahlan wants to buy and whooo wants to dispose :s13:
whoooo
A perfect match =:p
itchy hand lor...taobao buy so easy and impulse buying , lol my colleague also asking me to offload to her.= as she said she dont mind as she only just use the normal iqiyi and xiaomi apk nia . running xbmc on xiaomi1s is testing my patience
Rivers
Does changing to a wired connection help in the laggy-ness? It is really tough to watch a show without getting interruptions every so often. I am on a m1 100mbps fiber plan.
Tried both 2.4 ghz and 5 ghz wireless and still same outcome. Mi TV box is just next to the wireless router.
Kahlan
Thanks bro, will go read more, did not got so many. My colleague wants to buy from taobao so asked me if i want to get as well. he told me he getting the 2nd Generation.
A perfect match =:p
I'm still deciding between this, CS918 and the Mini X8H. by Mibox is the cheapest.:s22:
gregory_choo
If you want to buy now, it is better to go for himedia hd600a quadcore @rmb299.
The price is same as mibox. It is a more established tv box brand. Better CPU/GPU, 3 usb port, sdcard slot. external antenna, 8GB emmc.
Kahlan
Oh ok that's sounds good. Will go check that thread as well. Bro you got mibox ?
