Xiaomi Box Android TV Box
tckrto
I tried to follow the instructions but got stuck at the server address. Couldn't find a valid one to connect to. Which address u use for china server? The password and id is the 2 posted on the website right?
Edit. I manage to connect to one server but 认证 fails. Need to change other settings on mibox after connecting to the vpn?
No leh. I never change other setting.
matdrc
Anybody kind enough to provide instructions/links to rooting the latest 3rd gen MiBox?
Basically allow the box to run a clean android OS with Playstore
Greatly appreciated.
How can I know which version of the mibox do i have now?
hazekang
google play store isnt very useful cos most of the good apps (for the tv box) are not in play store
whoooo
See if you have the LAN port. if yes den you have the 小米盒子 标准版 aka MIbox 1S if not u have the 小米盒子 增强版 aka MIbox 2 aka Enhance aka Pro some even called it Mibox 3. the names depend who you ask.
Xiaomi officially has 2 version which is either the 标准版 or 增强版 since the very very 1st version was killed off
gregory_choo
Quote:
关于海外用户显示iCNTV认证失败的公告
由于近期政策限制,以及iCNTV未来电视的版权的原因,所以对海外小米盒子用户有一定的封禁措施,有可能会对部分海外用户造成影响,例如显示iCNTV认证失败等现象。对此带来的不便,深表歉意。特此公告!
小米盒子团队
2014年8月28日
iamlenon
yay got myself a xiaomi box..
duno simi version.. got lan port behind
but icntv all cannot watch
iamlenon
where to see it is written 小米盒子 标准版 or 小米盒子 增强版?
my chinese not good, navigate arnd cannot find leh :(
b3nzzz
How to enable lan in the box? i try off the wifi and on the ethernet but still unable to detect the network
whoooo
U mean written on the unit or Internet? If Internet just goto xiaomi.com without the sg
If u have tuzi launcher just goto the setting and it will point to Ethernet just click open
tckrto
I just now try using flyvpn super laggy... then after disconnected flyvpn can run iCNTV liao. Donno if I have found the loophole or iCNTV still fixing their geolock. Anybody got their mibox geolock can confirm?
Okay guys I found the loop hole for Mibox enhanced/pro version for firmware 1.3.44
Just using any free vpn service connect it successfully and run any movie to bypass the checking of IP first. Once completed you can stop playing the movie and disconnect the vpn service and watch any movie via iCNTV. Confirmed and tested already. But take note that once u completely shutdown your mibox u have to reconnect and repeat the steps to watch iCNTV. I do hope the it helps :)
S750WP
How to connect xiaomi to free VPN
