Xiaomi Box Android TV Box
silentscope
网趣云加速 VPN looks pretty good.
I am trying out the 60 days trial.
silencer13 - did you open up the app and connect your VPN? you need to do that before you can watch anything.
VPN price is at 56 SGD for 1 year 5 month subscription.. i think its pretty good.
But not sure if it is able to use other international IPs to support other web.
anybody can advise?
gregory_choo
anybody can advise?
It is strictly for china servers only. Once turned on, your links to other countries are cut off.
nervagent
questions
Hi all,
I have a few questions to ask before I make my decision to buy this box, am currently using the normal china andriod tv box.
1) Is the apple mirror inbuilt into the box or purchased seperately and is it compatible with my iphone 6?
2) The english OS, worth paying extra $10 in qoo10 or can I DIY by downloading off the internet. Is the english OS a crappy direct translation of the mandarin version or is it a proper OS done by the company itself?
3) I assume can download apps off Playstore?
THANK YOU ALL!!! :D
imacbie
Hi all,
THANK YOU ALL!!! :D
1) this is a hit or miss for me, dunno y but, it works but not all the time, oh yah, AirPlay is built in
2) no point spending the 10 bucks,
3) no, u will not have access to play store unless u root and install it yourself, isn't really necessary bcos u can just side load the apps
nervagent
thx for reply bro, im really concerned with the language setting, the MIUI got no eng setting? My chinese really quite jialat lol!!!
ekardo
anybody can advise?
this is VPN? I can able to watch all the icn tv now with this...since I watching mainly prc or hk stuff..no problem that I can`t watch others (US etc)
how much is it in S$? do you have to turn on everytime you sleep the xiaomi box?
glx
Yes this is VPN, app version. Price at ???????,??????,??????,?????????????-www.wangqu.cc
There is also VPN version that is cheaper but have to manual config.
mibox will have connection issue if you sleep it without deactivating the VPN. Rebooting will solve it.
Just Me
I'm using the vpn version as it can be applied on other platforms like ios and Windows. This only enables viewing for media which is geoblocked. It hardly speeds up downloading from sites like baidu pan. Also, it can't work with hk sites like mytvb/gotv/hktv
hotyrole
I saw this
I think should be able to ?
Or don't tell me it's one space, the other is ram
I bought the 1GB RAm though
hole
Can XiaoMi Box work with Singtel fibre?
If use VPN will it affect other connections? for example, my pc's connection.
Please advise. Thanks alot.:D:D
