Xiaomi Mi Max - Part 2
1982-1994
yeah calendar is the utmost important stuff to me in a smartphone these days. because i rely on it to track my income.
DRAGONGUY
See how long more you can take the rubbish audio crap... Kekeke.
I listen to mp3 and radio on the go. So, audio is upmost important to me. Now, with eu rom, the earpiece audio output quality is top notch and shiok to the max. :)
Tahan first. The thoughts of restoring makes me lazy and I don't like the idea of using mi account or other type to restore apps. The only stoppage point now is my call logs and sms.... 6k+ le. :s13:
Anyway the main reason why i don't use mi account to restore is that, it always mess up all my contacts and sms.
1982-1994
yeah i like samsung calendar since those days i was using galaxy note in 2011, it can attach with pics too. think i prefer it the most.
if not because of switching to other brands smartphone, i could have using it for years instead of business calendar.
DRAGONGUY
Icic, ya depends on individual ba. I used to track my things via the calendar. But now not much le. Anything will store in my brain, though sometimes tend to forget. But nevertheless non is important.
gundam77
Hi all Max'ers,
had finally hooted my MI MAX and will be collecting it within these 2 days from the Seller. Can any kind soul advise what are the few important MUST DO checks to do when checking out the set at the shop?
Had verified with Seller set is on Global ROM and with Play Store installed but how to check it's "proper" (hope I'd used the correct terminology) Global ROM and not some "fake" Global ROM etc? Had read up this thread from page 1 but am lost among all the wonderful advice by fellow active Max'ers like Kelvinti and Dragonguy etc...
Will post a screenshot of my Mi Max's details once I'd collected it - till then, so very excited to get my hands on it ASAP!!! :)
Sidler
Hi all Max'ers,
Actually, I think delivery would be a better option.
Still get a day or 2 to slowly check and try out the phone rather than the short period at the shop.
Global ROM has 4 numbers. E.g. 8.1.0.3
Latest Global stable for 64GB/128GB is 8.2.1.0, 32GB is 8.2.3.0.
If the "Updater" app prompts that a newer version is available, it's a real ROM. Only real ROM can update via OTA.
If it shows 5 numbers, e.g. 8.2.1.0.11, it's a fake ROM.
Go to Settings, About Phone. Tap on "Kernel version" multiple times. It'll launch the Hardware test menu. Run through all of them.
Can bring a powerbank if you want to try if the phone can charge properly anot, and a pair of earphones too.
actually fake ROM and genuine ones how to tell besides the build number?
cokiee
Whoa! Some serious calendar activity there. Looks to me also like you're using it to track account interest payout?
Anyway guys, check with you - is there a control for volume settings etc during call? Really finding it a problem that the call volume is soft.
Oinkize
Pressing up vol button does not work for you while on a call?
MIVEC525
Anybody using Circle.Life? Looks attractive.....$48 for 26GB...shiok!
raymysterio
Hi..notice if another party try to do a video call on snapchat..the phone wouldnt display any notification on this in the lockscreen..have checked the notification and autostart settings for the app but same problem...anyone having same issue?
On global rom
kelvinti
On global rom
Haven't you enabled the Locked Screen Notifications and Floating Notifications of the app?
kelvinti
BTW, folks who wanna flash to eu rom, stay at 8.2.2.0. Don't flash the latest 8.2.3.0 as I find it a little slower or lags a bit than 8.2.2.0.:)
kelvinti
Well..everything is on except the floating notifications. Let me on that and try again. Thank you
Also check the Other permissions of the app in the Security app to see if there is another needed restriction or privacy that need to be lifted. Example, Pop Up...
