Xiaomi Mi Max - Part 2
kelvinti
eh how to convert developer ROM to china stable ROM?
my pc failed to detect the COM port. sibeh sian.
Convert?
Yo mean using the miFlash to China Stable rom?
To double check. Your Device Manager or MiFlash cannot detect the COM port? :s11:
1982-1994
Convert?
yes using miflash to flash global developer to china ROM.
both...
kelvinti
both...
What miFlash veriosn are you using now?
miFlash official or miflash beta?
Try the other miFlash version (Official or Beta) if the version you are using now can't detect the com part to see how it goes! :s22:
1982-1994
both also can't detect the COM port.
kelvinti
:eek: Strange indeed! I''m not sure if it was due to adb error! :s11:
I can only think of this quick fix at the moment if you do not want to re-setup your 9008 from scratch....:s8:
Other gurus may be able to advise you with a faster way to fix. ;)
cscs3
Thats the problem when using Xiaomi products. Eapecially English version.
Shib
Folks on official Global rom 8.2.1.0 / 8.2.3.0.
Is the My Transport app can be downloaded via Playstore already? :s11:
I ask because I'm not running the official Global rom.. I can't test it at the moment.
Yes, i can download and install. i am on 8.2.1.0
cool_ocean11
Do you all notice that when you reset the phone the fingerprint sensor doesn't seem to recognize your fingerprint? you need to use the pattern or number to unlock
Shib
Yes. I deleted and re-add my fingerprints then it works again.
