Xiaomi Mi Max - Part 2
remoir
I read that mi max can do quick charge 3.0. anyone using any such chargers and cable? can pm me some brands if possible? Thanks.
cscs3
Volte is useful. It's note 4 that is not stable.
Volte works very well on lg and iPhone but also dependent on your operator network coverage.
Currently xiaomi's market share too small for operator to support volte...
Xiaomi do support Volte just that it is not compatible with local Volte.
Bte. Until we have good bandwidth with current 4G network. Volte is hard to take off here.
touchme
Shopee MiMax @ 208.88 limited to 1 set only.Is it possible to register another account to buy another set but delivery address is the same with New acc discount of $5 again ?
diff payment mode/cards can. Use dbsten5 for 10% off cap $10.
Oinkize
Yup. Xm supports volte in india but not in sg.
What operator are you with? I am with m1 and i have no issues with m1 4g coverage almost everywhere and the speed is decent.
Audiology93
Just be careful with that. Try putting different name and use different card.
Ordered 1x MI Max from shopee myself. Kinda miss the 6.44" after selling mine back in July :s13:
Sent from HUAWEI MHA-L29 using GAGT
cscs3
Starhub. Mostly only good coverage on city area.
kandinsky
It's not 'official support'. Not sure what your expectations are, but while you get a speed boost at some points (I measured up to 14W, it won't go max QC3.0 bandwidth of 18W), it's not for the whole charge. Overall from 0-100% it's not that much faster, my own tests, maybe only about 30mins less compared to non-QC? I find it most useful when you want to do a quick 'topup' say from 20 to 50%, or 50 to 80%. Aukey, Anker, Choetech, are the usual brands.
Pryson
Hi guys, got another new xiaomi max just arrived. Check the version 8.0.3.0 global miui 8. 64gb version. I check for system updates there are no updates. Why. Thanks
kelvinti
Opps!:s8:
Sounds familiar.....:o
You have gotten it from Simder, didn't you?
If so, this is the 2nd case I have heard of from simder...
kelvinti
Oh please. Starhub's 4g coverage is so cmi. If possible, try m1.
To me, SingTel is the worst! :vijayadmin:
Blind spot right at my dinning table! Half a bar and a No data signal at all ! KNN!:(
StarHub and M1 full bar at my dininig table! :s22:
1982-1994
lovin' this max though have been using it for coming to 5 months.
trying to adapt the usage without google,for longer usage of the battery.
I can't sync, but using dropbox to store my .ics calendar files.
justln
Opps!:s8:
Yup, I got from Simder also no auto update. Had to go manually flash it myself. :s12:
1982-1994
m1 is good but it keeps Android OS run non stop, battery drain 1% hourly on standby, experiencing this on my wife max and mine.
