Xiaomi Mi Max - Part 2
kelvinti
Hmmm... May be I should switch to M1 from StarHub for my upcoming recontract in April to try M1 for the next 2 years...
What do you think? Will I regret as far as 4G coverage / speed is concerned?
Intrinion
Senior Moderator
Senior Moderator
HSPA+ speeds and stability is not really ideal on my 6gb, 3G Starhub line imo. :(
Will get cut off / dc on trains
Oinkize
Yes you should. Get mss as well for more discounts.
Ender
Since you are using mi max, or export set, you don't need to be tied down with 2 years contract for a brand new phone, Get those mysim plan either monthky or yearly contract, then you can decide in a shorter period if M1 is good for you.
kelvinti
Oh Ya!
You have got the point. I will do just that! :)
justln
I should think of stuff to put on the phone, 92GB left. :s13:
kelvinti
Bluray JAV? I think 1 around 40+gb, can put 2 in. :s13:
Yeah! Afterall, Mi Max speaker is loud and clear and crisp...:D
Opps! =:p We 2 have better stopped here before kana bombarded and given demerit points by EDMW moderator for posting the AV stuff in the wrong thread ...haha. :s13:
PES1989
As of now, there's still no way of transferring games & apps over to SD card right for Xiaomi? Been googling for it quite a while but doesn't work.
My current Xiaomi Note 4G only have 6GB internal memory. Install few apps & 2 games then less than 1gb left liao.
amazingone
MIUI doesn't allow it, but the Mi Max should have enough space for you to store apps.
Sent from my Xperia using GAGT
1982-1994
I thought just do a local backup,copy the backup file into the SD card,transfer the file to another phone, download the apps and games,restore the backup file, can liao?
AnTiLooP
Just bought and setup this up for my mum and in doing so, I'm now quite keen to get his phone for my own use. Question to you guys, any issues with its size and your pockets ? It seems gigantic man.
Oinkize
For me still ok...
