Xiaomi Mi Max - Part 2
kelvinti
Just bought and setup this up for my mum and in doing so, I'm now quite keen to get his phone for my own use. Question to you guys, any issues with its size and your pockets ? It seems gigantic man.
You need deeper pocket pants and wearing a tight jeans can be a little bit of problem with it. Having said that, you still can slot it in amid a little squeezy.
Anyway, you wear tight jeans or hot pants everyday meh?
So, it is not an issue 99% of the time.
You can also slot it at the back pants pocket too at times.
Can buy. It is really good. Not too small and yet not too big to be carried around for media purposes.. :)
justln
As of now, there's still no way of transferring games & apps over to SD card right for Xiaomi? Been googling for it quite a while but doesn't work.
My current Xiaomi Note 4G only have 6GB internal memory. Install few apps & 2 games then less than 1gb left liao.
Nowadays the phones all have decent internal memory. Android is moving away from SD card too.
Nice! Welcome home, bro! :)
Well, unsealed and then sealed back has became a norm practice as long as it is a perfect set in and out, soft and hard! ... :)
Yup, a lot of shops got sealing machine. :s13:
zibellino
is it stable? i tried to flash .. but it's my first time.. unable to do so:(
you need to use miflash to flash and it is stable but no 4g on starhub anyway there is not much different from the miui 8 based on android 6 so i suggest you wait for better feature
Audiology93
zibellino
Just flash the latest built of lineage os on my mi max super smooth with multi windows it is like i bought a new phone
kelvinti
Browsing Aliexpress and found this case...:s8:
It looks quite nice! :s22: So, I ordered a Gold (non-sandy) to try at US$3.99.
https://www.aliexpress.com/item/For...32787741049.html?spm=2114.13010608.0.0.HWt7r8 :s22:
kelvinti
i have the gold one that you order but not using it now cos it doesnt cover fully cover the edges where the tempered glass stick
Ohh! I see!
I'm not sure if it covers fully without any tempered glass coz I'm not using any sp on my Mi Max at the moment?
Vtim
I thinking of getting a Xiaomi Max 64GB or 128GB. Anyone know where to get the best deal at this moment?
zibellino
Ohh! I see!
think it cover just the edges of the screen not more but just nice so a drop will not protect the screen that why i dont use it anymore
