What is gc?
Giftcards.. Buy in $100 denominations and get 3% off. Only drawback is that you cannot credit back to your bank accountWhat is gc?
Brother how to get 8.5.1
Hi all. Some of you may remember that I was trying to resolve the low volume music playback issue a while by flashing a locally-procured Max to the EU ROM. I never got around to it due to work, but with the latest OTA update to 8.5.1.0 (NBCMIED), on Android 7.0, it appears Xiaomi has resolved the audio issue.
Excellent stuff!
darn, don't need, but very tempting, another $10 off with qpoints.
Not sure as I don't have that amount of qpoints to test. Sure miss the days where it was easily obtainabledarn, don't need, but very tempting, another $10 off with qpoints.
OT, how come qpts can only deduct $10, tot was 30% or $30 max?
Good news.
BTW, is the auto brightness on 8.5.1.0 behaves properly?
What I mean is that does the brightness level goes back to the preset level after switching off the auto brightness?
U just need root and under clock the CPUs. Then the battery will last longer.Dunno why super battery drain again now.
Very sian. So tempted to get Mi Max 2.
No, it doesn't go back to the previous preset level after switching off the Auto Brightness.
Example:
With Auto Brightness OFF, I set it to say 20% brightness using the slider.
I then switch Auto Brightness ON, the slider moves, say, to 60%.
I then switch Auto Brightness OFF. The slider remains at the same setting (60%). It does not go back to 20%.
Hope that helps.
The part that has a gradient that is more flat is after I removed the microSD card from the phone.
Been a week moving on from mimax..
I miss mimax battery ! 10 hours sot is really no joke..
Hope xiaomi can improve their camera app
Sent from Sony E6653 using GAGT
After awhile, most people will realised that, without battery, the best camera phone will still not be able to take any picture at all.
If don't talk about screen size, cpu specs, etc .... the most important thing is battery life.
But different people have different priorities. So for those who have priorities for camera quality, then Mi Max is not the phone for them.
Wow. This battery app is powerful.Yes. It is a shame that mimax or xiaomi in general doesnt utilize the camera sensor properly and same time never release the source code for app developer to improve it.
Btw my second hand bought z5 is not so bad can still last a day (6 hours SOT) with same usage pattern as mi max
Z5 2900 mah. Mimax 4850 mah
Screenshot below is my Z5 custom ROM marshmallow based on stock
Just tested out with a huawei quick charger, the mi max can quick charge with the lightning in a circle. Estimated charge time is around half the time with original charger.
