Xiaomi Mi Max - Part 2
kelvinti
on eu weekly rom, has circle..
Bro, Check with you!
We must use twrp_helium_7 for flashing eu rom weekly rom
or any other Android 7 based eu roms, right?
Cannot use the normal twrp_helium coz it is for Android 6 only, right?
skrw105
not sure about this. i user-level only:o
so far have not updated the twrp, still using 3.0.2.0. for hydrogen.
did encounter flashing problem once with global beta 7.5.xx. before i unlocked bootloader.
i get the twrp from here;
https://twrp.me/Devices/
cochran
Hi guys
Like to check with u all here. Is there any data monitoring inbuild in xiaomi max phone on global rom?
Cant find it in setting.
Cos my mum phone on high data usage and want to find out which app is eating up the data.
Can advise or need to install 3rd party app?
Thank you.
Oinkize
Hi guys
Thank you.
You can use the in built security app.
Under data usage > data usage stats.
Kiwi8
Deluxe Member
What is the current price for Mi Max now and selling where?
Kiwi8
Deluxe Member
Difficult to find new set now.
Go Carousell. Plenty of 2nd hand mint sets if you don't mind.
I wouldn't mind, as long as the price is right. I will go check there then. Thanks. :o
Kiwi8
Deluxe Member
The main problem with buying a Mi Max now, is that searches are cluttered with results of Mi Max 2. :s22:
