Xiaomi Mi Max - Part 2
Phen8210
Good news.
BTW, is the auto brightness on 8.5.1.0 behaves properly?
What I mean is that does the brightness level goes back to the preset level after switching off the auto brightness?
im on 8.5.1 now, everything behaves normally without root. with root the brightness problem and no sim card detected issue surfaces, didn't had this issue with previous versions
kelvinti
Hmm... Your Brightness returned fast and correctly to the preset level after switching off Auto brightness?
Can try few more times to reconfirm?
Thanks.
kelvinti
I don't get much heat except using while charging. Otherwise just leave it to charge it's cool.
OK lah. As long as it is proven not damaging the battery and phone by charging it using a quick charger. :)
ramius_mark
Based on my understanding of electronics, using a QC on a non-QC device should not cause any damage. The QC circuitry will simply fail to detect a QC phone on the other end, and use 'base' or 'minimum' default specifications for charging (i.e. slow charging). Have no fear.
kelvinti
It's good to heard that.
Thanks, buddy. :)
kelvinti
Strange indeed! :s11:
When I was using official rom, there was a circle indicating fast charging.
Now, I'm using eu rom (China based rom), and there isn't any circle anymore! :eek:
The type of rom plays a part ? :s11:
skrw105
on eu weekly rom, has circle..
