Noticed EU ROM does not have the tap screen twice to wake function that the Global Beta has.
its a setting u need to enable. not on by default
Updated.Anyway, got new sound effects
I like the new sound effect.The Global Beta is getting better than the China Beta now....![]()
I'm considering Mi Max 2. Please share your experience here. Thanks.
Wrong thread lah bro. This is Mi Max part 2, not Mi Max 2...hehe.
Confusing title, I know... Haha.
What could be the problem when ringtones don't sound with incoming calls? (silence)
ringtones sounds when applying, also tried applying new audio files, but still in vain.
When u fast charge, u should see a PAP like logo. If u don't see that, then it is normal charging only.Was using a Samsung adaptor which was told charging was quite fast and can reach 100% within 2hrs. After using the same adaptor for 3-4 months, the charging became slower and now back to old slow charging time of 4-5hrs for full charge.
It is anything wrong with my battery or the charger itself. I'm afraid there isn't any other original Samsung adaptor I can compared with. I bought a couple of adaptor online from Q0010 which turn out to be fake ones and broken.
Gurus, please help. changed battery or get next original charger? anyone encounter this b4? Wife using the Max actually and very unwillingly to change handphone.
both, sounds when applying, but not when calls come in, muted.Are you applying the stock tones or your ownself custom tone to use as ringtone?
u r fast.Global Beta 8.1.25 up and running! (Mi Max Prime)
**Side Note: Global Stable 9.2.1.0 for Mi Max Prime has been released officially as well!
