Xiaomi Mi Max - Part 2
Sausage
using for less than 5 months on global stable rom but after around half a day the power is around 64%... last time i'm sure it lasted a lot longer. normal internet surfing, no games, only a few apps installed like chrome. is it normal?
Just Me
Install CPU spy and check if deep sleep is working when phone screen is off
Sent from 白イヌめブコロス using GAGT
kelvinti
As far as I have experienced.
Some apps or games don't work well or don't work with official Beta rom as well as eu Beta rom.
For example; pop up doesn't always show any content. SW2 is a good example.
Shib
New firmware.
Shib
it seems to be louder. I wonder they make change to the volume setting?
trichard
Today one of my phone received update to 9.2.1.0
But the other max didn't...
Anyone know why ?
kelvinti
Simi louder? Media Speaker mode or in headphone or phone call?
charleslee
K, I know my Mi Max (32gb running latest official global rom) is "old" now, but it's been acting up lately. Whenever I switch apps (ie. Between Facebook and chrome), the mi max seems to not hv enough memory to handle it.
The switched app might not open, and I had to go to recent apps, to close all apps, then they would open.
Also happens with just chrome and sms.
Also its frustrating when I tried to buy cinema tickets online and need to switch to sms to check my credit card verification sms, chrome would hang.
Actually, this seems to happen ever since I keep Bluetooth permanently on - coz of my mi band 2
Do I hv to keep Bluetooth off and only on it when I want to sync? Or is chrome taking up too much memory? (even with only 2 tabs opened at most)
3gb ram is not sufficient for Bluetooth or multitasking anymore? Or my mi max is dying and I need to switch to mi max 2?? �
kelvinti
Anyone know why ?
Bro! 9.2.1.0 fixed the double line notification bar, for example; WhatsApp?
"2 messages..."
"2 messages..."
kelvinti
3gb ram is not sufficient for Bluetooth or multitasking anymore? Or my mi max is dying and I need to switch to mi max 2?? *********
Have you ever done the cleaning using the stock "Cleaner" app?:s8:
kelvinti
Oh... Think now no even show one line..
Ahh! Simi situation here?:s11:
By Right, 1 line shows (Normal ) **Beta rom fixed it long time ago already.
By Wrong, 2 lines show (Abnormal).
Now, No Right or Wrong? (??? :s11:)
kelvinti
Yes. Does the stock cleaner damage some apps?
No lah! That Cleaner app quite safe one! :s22:
Hmm...Then, I'm not sure why.
May be some rough apps holding up the memory?
Come to the worst. Factory Reset your phone to prove the point.
