Xiaomi Mi Max - Part 2
Just Me
Anyone know if MiMax can use the Mi A1 firmware / OS?
Of course not.. even the Qualcomm processor is different for both models.. wait for Mi Ma 3... just hope it's not 7" as rumored though..
Anyone can advise where to buy new xiaomi max battery in Singapore?
My current xiaomi max battery can last hardly half a day. Had the phone for a year.
tansw2k
Anyone please recommend shop/dealer repair? Mi max u unable to detect WiFi immediately after update to nougat and firmware 9.2.1 global stable rom
ZrE0_Cha0s
Mi max battery is build in one how to get a new battery??? :s22:
next u may try your luck in SLS for the battery replacement. (but bear in mind there are some risk as well)
ZrE0_Cha0s
well if u dun mind, i think u can try to downgrade it again to try. or maybe try your neighbour's wifi to test if really its your phone issues.
tansw2k
Tried , but problem persist. Tried flashing as s well, but stuck with device could not detected while unlocking bootloader
Shib
You want to double check the firmware against your hardware model? There are 2 models: the Prime and non Prime. You need to download the right one...
tansw2k
Yes, mine is the non prime 32gb. It's correct
TheOutsider
For those who can't get VoLTE, can try this code in your dialer
*#*#86583#*#*
This will disable VoLTE Carrier check.
Then you can turn on the VoLTE option under SIM Card option.
Mine directly go into VoLTE after setting this on SingTel. Finally found the right solution to this problem.
The setting persists after reboot.
winningeleven
My local Mi Max battery also gone case after 14 months. I went to the service centre at Clarke Quay to replace it at $52. The battery itself cost $15 and the rest is the service charge. I went at 11am and collected after 1230 although the service guy mentioned earlier it would be evening 5pm.
If your is a export set. Service centre won't fix for u. Then probably u can try carousell where someone charged for $45 inclusive installation
Shib
*#*#86583#*#*
Nothing happens for my set...
kelvinti
Hosei! :)
Whether it works or not is another matter. However, I'm happy to see the VOLTE option. At least, I song sia! Haha. :)
TheOutsider
Hosei! :)
Try *#*#4636#*#* -> Phone info (1 or 2 depending on your SIM Card) -> VoLTE Provisioned turn on.
Mine after on can straight away see VoLTE logo all the time at the top.
Btw you might want to delete your photo before anyone starts calling you :D :D You showed your phone number.
kelvinti
It is on but no VOLTE. Starhub no good friend with Mi Max... . :(
ZrE0_Cha0s
Volte iirc it depends on both side supporting it. If 1 side does not support u won't get volte.
But still starhub should be having it. Since iirc, they were the one that came out with HD+ voice which is similar to volte.
kelvinti
You have got the point. Let me enable the VOLTE on my other Mi Max on StarHub and test calling again later..
