Xiaomi Mi Max - Part 2
sjchai75
You have got the point. Let me enable the VOLTE on my other Mi Max on StarHub and test calling again later..
I enabled mine for M1. Let's see whether I got that or not. Last month, when I was in China, using China Mobile, I can see my call and data speed reached 4G+.
TheOutsider
For sure all Telco support. It's just whether they block it for our phone.
Maybe can check with your Telco also whether your plan has the clear voice/HD voice etc add on to use Volte
Sausage
is it possible to change the battery ourself
is the soldering simple or got funnie connections
windwaver
Hey guys, for those Mi Max 1 users with the snapdragon 650.
Does the phone tend to heat up during long gaming? Does it throttle often?
TheOutsider
It's inevitable. The S650/652 are based on 28nm and has higher performance cores when compared to the S625/S626 that's used in many of the newer device even with lower performance cores but using 14nm.
So if you compare it to more current devices using 8x Cortex A53 (Like S625/626/630) and also newer chips like S636/S660 for sure it should be generating more heat.
cscs3
For gamming, SD625 is slow vs SD650.
Jhyun
I have max 1 and Note 3. What is heat? What is throttling?
I only see and feel max 2 slower.
Sausage
did anyone here change their mi max 1 battery themselves? is it difficult?
TheOutsider
You sure no throttling??
:D :D It's smooth playing most of the time but some game can really kick it into overdrive then heat up and start throttling.
I am not saying that other phone won't act the same playing the same games ya...
Jhyun
Tbh, I don't play games. I have a dedicated console for that.
But everyday tasks, the mm2 is significantly slower.
So even before mm1 starts throttling, if it ever does, it is already faster than mm2 which probably feels like choking all the time.
