Xiaomi Mi Max - Part 2
maxlovely
This I agree. Upgraded to a 128gb and other than seeing more spare ram in task manager, the performance increase is hardly visible.
Not really worth upgrading if you already have a 32 or 64 unless the price is cheap or you just want to upgrade for onboard storage or just for the sake of upgrading.
I have 32gb and 64gb, not much diff.
I also have a 128gb iphone and the available space is 90gb..so if really need to large storage then get 128gb.
alvismah
my phone brought from newstar. you guys uses which tutorial to root ?
so far the shortest ever since the phone was rooted.
kelvinti
Gold at $359 or minus further with whatever codes you have is still worth it for 128. :)
Don't wait!
1982-1994
there is a file which is bundled with twrp (for respective variant of max) so that you can skip the unlocking boatloader process. which makes things much easier since you doy not have to wait for permission from Xiaomi.
yours rooted?
why root? to control your phone CPU,remove ads, disable battery-hogging-stuffs you don't need,which does not affect the performance of the phone at the same time. (that explained my short list of running apps list)
alvismah
which tutorial u used to root ur phone ?
yours rooted?
Krabs.
Correct ba! :s22:
64 and 128 are using the same Global rom. They are both categorized as "Mi Max Prime". :)
I thought the 64gb version less 2 cpu cores & 1gb ram ? no issue if use PRIME rom ?
kelvinti
Actually, you confused ba. The 64 has 3gb ram but cpu is the same as the 4gb 128.
Obviously and technically, the rom knows how to configure the 64 and 128 accordingly ba.
mojojoel
yours rooted?
No need TWRP to skip unlocking permissions from Xiaomi, just use fastboot ROM + EDL mode.
then probably 64gb&128gb are sharing the same ROM.
Yes, 64/128 are sharing the "helium" ROM.
Nope. Just do it.
i1magic
Those who want Playstore but cannot do Google login, just use APKPure app.
https://apkpure.com/
Works like Playstore without the need to login with Gmail. Can update other apps via the app too.
ZrE0_Cha0s
but tbh when apps stated that their version varies by devices, will it still work even when updated to the latest one?
max24328
Hi, anyone know where to get full tempered Glass?
The one they provided got bubbles at the side..
acura_ra
thinking of getting 3gb/64gb from jbtc group on shopee, its gg for $309. anyone has any experience with them? and also any promo codes to recommend?:s22:
ZrE0_Cha0s
i get from taobao but not totally transparent, i got those have cover on the top and bottom with a bit on the size. but cant see any bubbles at the side.
