Xiaomi Mi Max - Part 2
kelvinti
from the miui global rom page at http://en.miui.com/thread-526049-1-1.html
there are 2 roms
fastboot and recovery
which one am i supposed to use
Yours is Mi Max 3/32 or (3/64 or 4/128)?
Those are Beta/Developer rom.
You should use Global Stable 8.2.1.0 and use the Fastboot ROM to flash your Mi Max.
3/32 Fastboot ROM here!
3/64 and 4/128 Fastboot ROM here!
Unless you wanna flash the beta / developer rom which I don't suggest for you at the moment. Coz, later you kpkb this app doesn't work, that app doesn't work, seriously.....Kekeke.
Sausage
how do i flash this global rom? do i need a pc? can i do without pc? I want to avoid installing all kinds of things on my pc.. messed a lot of things up previously when i was using samsung phone
ZrE0_Cha0s
Well u can try downloading the ROM and see if u can do it from download update option(if there is 1) but I did it with PC.
i1magic
did you use mi flash? mine keeps crashing
I just tried using MiFlash Beta to flash for my friend's Mi Mix but it keep crashing.
Can anybody confirm whether is it the MiFlash Beta problem?
Anybody knows how to flash stock global / Developer firmware via stock Recovery?
Will installing TWRP disable Auto Update for firmware?
Sausage
i am using mi flash 2016.8.30
i try to point it to the directory where i put the rom you said
but the rom is not even listed for selection
how ah?
skrw105
unzip the file twice, ie, tgz->tar-> folder. then point to the folder.
how ah?
1982-1994
i think twrp disables auto update.
which method of flashing? EDL, fastboot?
that time I was in the same situation, but succeeded using EDL.
kelvinti
Anyway,
I'm on Global developer 7.3.2 now. Decided to go with developer rom as it has fixed many stock apps and 3rd party apps problem as compared to Global Stable. :)
i1magic
Can anybody confirms that installing TWRP will disable Auto Update?
I tried but I can't put the Mi Mix (not Mi Max) into EDL, can only put it into "Fastboot". When I clicked "Flash", it only take 1 sec and it show "Success". At the same time, Windows prompted that MiFlash is beling "force closed".
Maybe Mi Mix is different from Mi Max.
Sausage
i keep getting 'miflash has encountered an error' when i try to flash. does this mean i really have to wait for the sms to unlock?
1982-1994
unlock? you don't have to wait for SMS in order to flash unless you want to root.
Sausage
this is the error
http://imgur.com/a/OsP36
i tried uninstalling and reinstalling multiple times, same error
KalTorak
this is the error
Hi, please make sure to boot the MiMax in EDL mode which displays a blank/black screen instead of fastboot mode (phone logo and usb cable). Once you hit Refresh in MiFlash Tool, it should show device as COM3 or something similar.
Here is a simple guide for your reference (you can use the latest MiFlash instead of beta) :
http://xiaomitips.com/guide/how-to-flash-miui-fastboot-rom-on-mi-max-with-locked-bootloader/
