Xiaomi Mi Max - Part 2
Sausage
ok done
flash was successfull it said
but now booting and showing the mi boot screen for 10 minutes already
kelvinti
ok done
How long it took for the miflash process?
10 seconds or sort of 20 minutes?
If 10 seconds means failed even it said success. It must be about 20 minutes.
The left panel must be showing COMXX where xx is number.
Krabs.
the online price across the board went up since early feb .... I think wait for mi max 2 mid-year better
touchme
that's the sign of miMax2 reverting to Mi series pricing, $500 upwards, since miMax1 turned out to be a successful experiment
Krabs.
that south american guy left xiaomi and they failed to hit market share targets ....
they dare to up price ?
cokiee
Think the 128gb is still cheapest on shopee, at 369 - been this price for a while. Wonder if it'll drop in 2 months when version 2 comes out.
rootz
I sure hope that they will drop mi max price. We'll, if they drop mi Max 2 price, even better.
128GB at 369 is a good price.
Qoo10 has one ard that price too.
i1magic
I just tried using MiFlash Beta to flash for my friend's Mi Mix but it keep crashing.
Can anybody confirm whether is it the MiFlash Beta problem?
Anybody knows how to flash stock global / Developer firmware via stock Recovery?
Will installing TWRP disable Auto Update for firmware?
Ok. Problem solved. The Mi Mix (Not Mi Max) needs to be unlock the bootloader for it to work.
After the bootloader is unlock, the usually fastboot flashing procedures will work.
i1magic
I am on the latest Global Beta firmware on my Mi Max 32GB.
The video playback has lag. I tried with a few other players, the lag is still there. So should be due to some hardware / software acceleration issue.
http://en.miui.com/thread-529273-1-1.html
If any of you also on the same firmware as I am and are experiencing the same issue, please go to the above link to "confrim" on the fault.
Thanks.
