Xiaomi Mi Max
Nakedtoes
Redmi pro is only for those who want good camera else dun bother.. Mtk cpu yr update will slow like crazy but still faster then other brands
kelvinti
No lah, 6.7.29 is higher version number than 6.7.5.
29 > 5, correct? Just that they don't put 6.7.05 and people get confused.
It is still their fault for not putting .05 and made us likes a fool!...:vijayadmin:
Basic wah! :D
bbcccc
something to ask, am currently on 7.5.4 china rom
can i download the 7.5.6 global rom n update via the 3 dots in updater?
bootloader unlocked le...
heng8888
1) Download the latest MIUI 8 Recovery ROM file. Rename the downloaded ROM file to ‘update.zip’ on your computer.
2) Head towards Updater App, click on the "3 dots" (top right-hand coner) and choose "Choose update package",
3) Go to "Download" folder and Choose files, and choose the Recovery ROM zip file you just copied from the PC/Computer and select and tap "OK".
4) It wil then verify the the package "Getting info" and reboot automatically and flash the Recovery ROM accordingly, as shown below:
Thanks bro, really appreciate yr help.. i'll go home first & think it through thoroughly..
kandinsky
India selling it at rs14999~sgd300,
how is it lazada selling as $285 ?
Btw, although Lazada sometimes sells products, in this case they are just providing the platform (like ebay, carousell, etc). Smartcell pte ltd is the seller.
Maybe they have contacts for wholesale pricing? *shrug*
kelvinti
Refurbished mi max means what?
But it's new set u received right ?
No lah!
I was just joking...:D:D:D
They may get from India from "back door", under the table" or under the chair" or "under the skirt" ...? :s13::s13:
Don't know and don't care lah as long as it's cheap and comes in an original sealed box! We have to trust SMARTCELL. don't we?! :s13::s22::)
Nakedtoes
After 2 days usage got used to the size.. Not as Hugh as my previous Z ultra.. Wonderful phone at such cheap price...
