Go for mi max if you want something bigger. However, if you decided to stay with 5.5", why not look at the Redmi notes 4? It also has a large battery at 4100mah. To me, a down sized mi max. Price whiles is not a lot of different from the remi note 3.
Hi all, there's 2 questions I have for fellow mi max users:
1. How do I change the from default lock screen keyboard to the selected input one (Swype)?
2. After every restart, my theme/wallpaper will always switch back to the default one instead of the selected wallpaper.
How do I rectify these 2 issues. I'm using Nova Launcher btw. Thanks in advance.
After watching this .... I think you'll think twice before getting Redmi Note 4 liao.
If you're using 3rd party launcher then the problem is with the launcher no?
I'm using stock and don't quite understand the problems you're seeing. E.g. My lock screen got no keyboard leh.
Yes, I also like to know whether there is a solution for question 1. But I think this cannot be changed.
Sorry bro, can't help you on both questions. But, I did not experience what u mentioned in question 2.
I don't get it leh?
What was the Note 4 in the video?
I don't get it leh?
Hi bros , I am using mi max 64gb on global stable 7.3.14 , do I have to manually update to MIUI 8 ? Will I loose all apps and settings ?
Only in silver?Official local Mi Max (3GB/32GB) is now available on Lazada: http://www.lazada.sg/xiaomi-mi-max-32gb-silver-8422331.html~
Sent from Sumire using GAGT
