Xiaomi Mi Max
Nakedtoes
Lazada selling 284.90 before discount code and shopback rebate.
Seller is Smartcell mobile
worth it to get?
thinking to get Mi Max or Redmi note 3 silver ($215 before all the discount etc)
Both export sets from Smartcell mobile.
pls advise me.
mY current phone is already 5.5inch
thank you very much
Mi max is better that is if u are ok with the size
i1magic
No not normal. 6.8.25 was out last week, and 6.9.1 Global ROM beta just out today.
Quite a large update this week. :)
Just upgraded liao. Will monitor.
i1magic
worth it to get?
pls advise me.
thank you very much
I have some problem getting used to the Mi Max size. But after using Mi Max for awhile, now when I use the Redmi Note 3, it feel so small and handy.
But the usage of the Mi Max was made better because I use the "Ring thingy" behind the phone.
kelvinti
Strange, I don't get any OTA for MIUI8 either. Currently on Global 7.5.7.0 stable
If you are on MIUI7 Global Stable 7.5.7.0 or any official MIUI7 Global Stable versions, you will not get any OTA for MIUI8 Beta...;)
Only those we are already flashed to and running MIUI8 Beta will get the subsequence MIUI8 Beta OTA! :s22:
kelvinti
I slot my Mi Max at the back pocket now! No more kkj thingy!
As for the "ring" thingy....better keep in on bed..!Haha! :s13:
kandinsky
worth it to get?
pls advise me.
thank you very much
I was in similar position. Had a 5" phone. Looking at those two. Went for Mi Max cos I didn't mind trying the size. IMO, these phones are low cost enough that if it doesn't work out, can easily sell and buy the other one.
It depends on your own preference. If you are very very satisfied with 5.5", zero interest in trying anything different then stick with it. If you are curious about a larger phone, then mi max.
jameshong
Just wanted to share another 2 methods of taking screenshot on mi max phone beside the usual one (Volume down and Power button)... :s12::s12::s12:
1. Screenshot button method of taking screenshot:
Go to the screen on which you want to capture screenshot.
Now, access quick setting menu.
Tap on to the Screenshot button.
Screenshot will be taken.
2. Volume down and Navigation button (Menu) method of taking screenshot :
Go to the screen on which you want to do print screen.
Press volume down and tap on navigation button (MENU) at the same time
i1magic
worth it to get?
pls advise me.
thank you very much
If you want Android 6.0 and a phone with longer lasting battery and can "tahan" a bigger phone, go for Mi Max.
sellun
Another 2 method which I find easier is, totally no need hard button.
3. Add screenshot shortcut to quick ball. Just swap and take screenshot
4. If you're on miui 8 can turn on swap 3 fingers to take SS. This is the best method for me.
Sent from MiMax using GAGT
DaRRenLieW
Please hoot and buy guys. Been using since launch no problem. Dont worry about export or local. For the price you pay by the time the phone spoil you already cover your loss !!
Guarantee battery lasting , battery dont explode XD
Super heavy usage SOT 10hour easier, no fight !!
:s12::s12::s12::s12::s12::s12::s12::s12:
kelvinti
so is the volume back to normal loud with the latest update?I'm still with miui 7.
Well...
The moment one activates the Mi Sound Profile in Headphone music mode, the volume drops to very low again and that you need to kill the Music app for the volume to come back normal.
So, it is still not fixed yet in 6.9.1. :(
kelvinti
Ya! Hoot the Mi Max. Big Screen size for video and gaming and battery life are no fight... :)
That's why I U Turn.... :)
tohwk
Hi all, there's 2 questions I have for fellow mi max users:
1. How do I change the from default locked screen keyboard to the selected input one (Swype) to enter password for unlocking the phone?
2. After every restart, my wallpaper will always switch back to the default one instead of the selected wallpaper.
How do I rectify these 2 issues. I'm using Nova Launcher btw. Thanks in advance.
sumkong
worth it to get?
pls advise me.
thank you very much
Go for mi max if you want something bigger. However, if you decided to stay with 5.5", why not look at the Redmi notes 4? It also has a large battery at 4100mah. To me, a down sized mi max. Price whiles is not a lot of different from the remi note 3.
sumkong
worth it to get?
pls advise me.
thank you very much
Wanted to hoot 128gb one but seems like no global rom available yet :(
Me too looking at 64 or 128gb. Well, use 32gb first for the time being. Until when global stable rom is out then get the higher capacity. The best thing is this phone is pretty affordable, buy 2 of them is still less than the price of an iphone or a Samsung notes.
sumkong
1. How do I change the from default lock screen keyboard to the selected input one (Swype)?
2. After every restart, my theme/wallpaper will always switch back to the default one instead of the selected wallpaper.
Yes, I also like to know whether there is a solution for question 1. But I think this cannot be changed.
Sorry bro, can't help you on both questions. But, I did not experience what u mentioned in question 2.
