Xiaomi Mi Max
trichard
After 3 days , I really LOVE this babe............ Big screen BIG Batt Good stable MUIU ....
and Best ... it is the price ......
Wonderful phone.
Nakedtoes
Export set after coupon can get below 220..warrantied set abt 320..$100 differences.. U all big enough to know worth it or not
Compact7
Export sets is risk seller flash modified rom. Now only 32gb got global rom. 64 and 128gb only China rom. If u get export global rom 32gb it is exactly same as local set but wo warranty. Warranty to me is redundant. My past few phones all export except note3 all no problem after 1 year
The latest rom for 64/128 is not global?
Compact7
From what I know the 249 in lazada is lazada price. The shop walk in is different.
Call them to ask.
Oinkize
64/128gb has global stable ROM already...
Oinkize
Well... i only use miflash beta for my method... some say can use the stable miflash... so... not sure since i no try the stable miflash....
But.... it can be many problems arise to that... maybe he never use the vol+, vol- and power button mode (black screen) and use the normal fastboot mode........ maybe cable is faulty/dirty..... maybe usb port is sot/dirty....
I used mi flash stable. No issues...
DRAGONGUY
i can only guess that my miflash beta software may not be updated? tonight i will check the beta version, or even try the stable version.
i did follow the steps into flashboot mode.. you mean you're suppose to get a black screen? i hold the vol keys and powder keys and the xiaomi/andriod mascot fastboot screen showed up...
i also dunno why my phone not detected as COMxx, the 6bXXX i got yesterday was the same when i flashed the Miui 8 CN rom
I guess it so... that u went to the normal fastboot mode... if yours is unlock bootloader no problem for normal fastboot....
You will need to press hold vol+, vol- and power button to get the black screen mode (nothing on screen)... Once it vibrate means on le, then you can release all.... normal only few secs to on it nia.....
If press all 3 at once difficult for you... press and hold vol+, vol-..... then press and hold power button while still holding the other 2....
DRAGONGUY
Haha! :s13:
Black screen (Fastboot mode) method has been successful in every of my flashings between Global Stable and Global Beta using the official MiFlash! :s22:
Ok loh.... good for you... i think i did try before..... or maybe not..... old liaoz.... memory nowadays no good..... it (latest official miflash at point of flashing) failed on me..... that's the only one time failed..... so should be ba..... maybe i suay....
Must be i suay.... first time flash to china rom from vendor rom using the pcsuite method bootloop-ed liaoz.... while other ppl can.... so must be la....
DRAGONGUY
Download and use the latest version of official MiFlash. Don't use beta anymore after the latest official MiFlash was released as per MIUI Team weeks back! In fact, the MiFlash Beta has been discontinued likes the Note 7!:s22:
Sometimes..... old things are better.... oh wait... u comparing new and old.... old and new... hmmmm.... nevermind.....
